Design questions November 26, 2014 03:14PM |
Re: Design questions November 26, 2014 11:06PM |
Re: Design questions November 27, 2014 06:06AM |
Re: Design questions November 27, 2014 02:58PM |
the_digital_dentist
Any design can be made strong, but you have to use the right materials in the right way.
Re: Design questions November 27, 2014 11:24PM |
the_digital_dentist
One thing I can recommend it that you use one motor and a belt to drive as many screws as you will use in the Z axis. Using separate motors is cheaper, but you will curse every time one of the motors gets out of sync with the others, tilting the X axis boom or the print bed. It is also easier to make adjustments on the machine when you can raise/lower the X axis or bed by simply pulling on the belt, knowing it won't cause any alignment problems later
Re: Design questions November 28, 2014 01:23AM |
Re: Design questions November 28, 2014 02:34PM |
Re: Design questions November 29, 2014 02:03PM |
Re: Design questions November 29, 2014 05:01PM |
Digital_dentist
With two motors you're making an assumption that the steps the motors make are always exactly equal. I would trust the native steps the motors make to be pretty close, but with microstepping the motors won't necessarily both stop at exactly the same angle. The errors result in slight wobbling of the X axis boom (or the print bed) as it moves up or down. Is it enough to cause visible errors in the print surface? I have seen a lot of prints from a lot of printers that use two motors and a lot of them seem to have print quality problems in the Z axis. I don't know if it's because the motors aren't matched, the screws aren't matched, or other mechanical problems, but I'm always in favor of trying to eliminate sources of error and unreliability. When in doubt, fix it before it becomes a problem.
Re: Design questions November 30, 2014 01:18AM |
Re: Design questions December 01, 2014 09:05AM |
