Extruder stepper motor temperature? January 07, 2015 12:35PM |
Re: Extruder stepper motor temperature? January 07, 2015 02:18PM |
Re: Extruder stepper motor temperature? January 07, 2015 02:33PM |
Re: Extruder stepper motor temperature? January 08, 2015 04:52PM |
Re: Extruder stepper motor temperature? February 10, 2015 03:57PM |
Re: Extruder stepper motor temperature? April 19, 2015 04:10AM |
Re: Extruder stepper motor temperature? April 19, 2015 08:21AM |
Re: Extruder stepper motor temperature? April 20, 2015 09:09AM |
Your motor's operation on your printer does not necessarily indicate what other's may experience. Steppers are usually rated to operate with a 40-60 deg C temperature rise if not more. So even at the low end, they can operate quite warm to the touch with no issues. "Quite warm" also isn't a very scientific measurement. How exactly warm is "quite warm"?Quote
alexella
Your extruder stepper should not run "quite warm"
I'm having my Delta printer working for 3 hours, a bowden extruder that's 50cm long and the motor temperature is preciselly 36C.
Re: Extruder stepper motor temperature? April 20, 2015 01:54PM |
the_digital_dentist
There's no need to try to match the masses of the extruder carriage and the bed. In general you want to keep moving masses as low as possible because the motors will do a better job of controlling the motion and that will translate to better print quality. Whichever axis has the greater mass will limit the maximum print speed/acceleration of the machine, assuming equal torque motors on both axes, and assuming the extruder can keep up.
KH42KM2R001D is a 1.7A motor.
Re: Extruder stepper motor temperature? April 20, 2015 01:58PM |
cdru
alexella
Re: Extruder stepper motor temperature? May 09, 2015 04:03AM |
Re: Extruder stepper motor temperature? May 11, 2015 09:22AM |
o_lampe
This is true, but steppers rarely have any magnets inside...
I´d take a close look for stepper current, because of the stepper drivers. They are the weakest part in the chain IMHO
Olaf
