Hi!
I have no experience at all with bowden setups so I can´t figure out whether my current print problem has anything to do with the bowden setup.
I have a bulldog XL extruder with the thin PTFE tubing (5mm outer diameter) and unfortunately a fake e3d hotend (which I don´t like) but that came with the printer I am testing at the moment.
My real e3d is direct driven 3mm and this printer came with a bowden setup so the hotend does not fit. Also this is the first time I use 1.75mm filament.
What I also don´t like is that the 1.75mm filament has lots of space in the 5mm (outer) PTFE tube that came with the extruder ( the thicker one has 6mm outer diameter).. so maybe my printing issues come from the fact that the
tube is too wide and the filament acts like a spring inside the tube)
Please take a look at the picture... what could be the cause of the problems I have at the corners?
Extruder feedrate is set ok ( I think), x,y and z steps are OK.
open |
download -
(167.1 KB)
