Help Needed - End of My Tether With Heated Bed September 28, 2015 04:45AM |
Re: Help Needed - End of My Tether With Heated Bed September 28, 2015 05:51AM |
Re: Help Needed - End of My Tether With Heated Bed September 28, 2015 07:22AM |
Re: Help Needed - End of My Tether With Heated Bed September 30, 2015 05:25AM |
Re: Help Needed - End of My Tether With Heated Bed September 30, 2015 08:16AM |
Re: Help Needed - End of My Tether With Heated Bed September 30, 2015 08:30AM |
the_digital_dentist
People put insulators on the bottom side of the heater because most have underpowered heaters supplied with cheapo kits that will take forever to heat the bed up to print temperature if they lose any heat on the underside. You don't have that problem.
Re: Help Needed - End of My Tether With Heated Bed September 30, 2015 01:49PM |
dc42
The other reason is to protect whatever is under the bed from overheating, as is the case here (soft plastic parts under the bed) and on my delta (electronics and PSU under the bed).
Re: Help Needed - End of My Tether With Heated Bed October 01, 2015 06:55AM |
