Making X and Y axis perpendicular July 31, 2016 05:04PM |
Re: Making X and Y axis perpendicular July 31, 2016 05:31PM |
Re: Making X and Y axis perpendicular July 31, 2016 08:34PM |
Re: Making X and Y axis perpendicular August 01, 2016 03:01AM |
the_digital_dentist
3D printer firmware (and the slicer) makes certain assumptions about the printer, including an assumption that the axes are orthogonal.
Re: Making X and Y axis perpendicular August 01, 2016 07:46AM |
Re: Making X and Y axis perpendicular August 01, 2016 02:00PM |
the_digital_dentist
Doesn't RepRap firmware make the assumption that the alignment of the axes is fixed? With two Z axis motors, the alignment can change.
Re: Making X and Y axis perpendicular August 01, 2016 02:41PM |
Re: Making X and Y axis perpendicular August 01, 2016 04:06PM |
the_digital_dentist
On dual motor Z axes you could put a zero sensor at each end of the X axis and run the two motors until both have tripped their respective z=0 sensors.
the_digital_dentist
You might also have to add rotation sensors to ensure that both screws are turning or the system could do some damage if one screw is jammed and the other keeps turning.
