Re: Replace timing belts with FireLine May 27, 2018 11:01AM |
Re: Replace timing belts with FireLine May 27, 2018 11:27AM |
Re: Replace timing belts with FireLine May 27, 2018 11:58PM |
Re: Replace timing belts with FireLine May 28, 2018 03:20AM |
Re: Replace timing belts with FireLine May 28, 2018 04:39PM |
Re: Replace timing belts with FireLine May 30, 2018 06:26AM |
Re: Replace timing belts with FireLine May 30, 2018 09:08AM |
Re: Replace timing belts with FireLine May 30, 2018 11:58AM |
Re: Replace timing belts with FireLine May 31, 2018 04:20AM |
sqrt(200²-4.2²) = 199.95
Re: Replace timing belts with FireLine May 31, 2018 05:50AM |
Re: Replace timing belts with FireLine May 31, 2018 12:52PM |
Re: Replace timing belts with FireLine May 31, 2018 03:36PM |
Re: Replace timing belts with FireLine June 01, 2018 01:37AM |
Re: Replace timing belts with FireLine June 01, 2018 01:56AM |
Re: Replace timing belts with FireLine June 01, 2018 09:58AM |
JoergS5
I will try your solution for the Y-axis: a double shaft stepper in the middle, connected by two shafts to the side, then ... ok, I made a "professional" picture.
Re: Replace timing belts with FireLine June 01, 2018 01:39PM |
Re: Replace timing belts with FireLine June 02, 2018 04:00AM |
Re: Replace timing belts with FireLine June 12, 2018 11:50AM |
M_Xeno
I found that a strong Kevlar string coupled with an original Gates GT2 belt, with a minimal lenght, gives less ringing... The idler pulley may be a simple V-groove ball bearing, it's very reliable.
Re: Replace timing belts with FireLine June 12, 2018 04:35PM |
Re: Replace timing belts with FireLine June 12, 2018 05:05PM |
Re: Replace timing belts with FireLine August 25, 2018 02:27AM |
Re: Replace timing belts with FireLine August 26, 2018 03:07AM |
Re: Replace timing belts with FireLine August 26, 2018 05:21AM |
Re: Replace timing belts with FireLine August 26, 2018 06:03AM |
Re: Replace timing belts with FireLine August 26, 2018 06:17AM |
Re: Replace timing belts with FireLine August 26, 2018 09:41PM |
Re: Replace timing belts with FireLine August 26, 2018 10:00PM |
Re: Replace timing belts with FireLine August 27, 2018 12:44AM |
If I'd use thicker washers to set the vertical offset, the wires wouldn't rub against each other.Quote
JoergS5
The wires must be forced to a specific angle between corner and the middle. In your case the wires force each other into this angle, but you have friction and maybe abrasion.
TBH, I haven't tried it with a single multiwrap idler, like polygonhell designed it. What bothered me in his design is the bigger height of the assembly and the higher sideload to the stepper bearing. Here it's is very flat and the tension pulls only at the base of the shaft.Quote
Trakyan
Out of curiosity, what's the advantage over just jogging the cable between two axles like in the original design? It just seems like this would be harder to string.
Re: Replace timing belts with FireLine August 28, 2018 02:50PM |
Re: Replace timing belts with FireLine August 28, 2018 04:18PM |
