Brake vs. shorting stepper coils October 21, 2020 03:33AM |
Re: Brake vs. shorting stepper coils October 21, 2020 06:38AM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: Brake vs. shorting stepper coils October 21, 2020 08:46AM |
VDX
... disconnecting the coils from the driver under load could/will wreck/burn the driver !!
Re: Brake vs. shorting stepper coils October 21, 2020 10:29AM |
Re: Brake vs. shorting stepper coils October 21, 2020 10:36AM |
Admin Registered: 11 years ago Posts: 3,096 |
the_digital_dentist
While you're solving chicken and egg dilemmas, here's another one to think about:
Re: Brake vs. shorting stepper coils October 21, 2020 10:56AM |
Well that sounds like a chicken and egg problem to me...Quote
the_digital_dentist
Why does shorting the coils brake the motor? When the bed drops the motor spins and generates EMF through the shorted coils that create a magnetic field that bucks the rotation of the motor and the dropping of the bed. But, if the motor isn't spinning, there's no current being generated and no magnetic field, so no braking.
What was I thinking posting a request for a solution to a problem with set boundary conditions. Everyone knows when you post a request like "I want to build a printer with this and that hardware configuration and want advice on one particular problem" the answer will be "Rather build a CNC instead, this won't have this problem, duh" No wonder the forum is dying...Quote
the_digital_dentist
Ball screws are usually low friction, relatively long lead devices. That almost guarantees the bed will drop when Z motor power is cut. If you use short-lead lead screws (1 or 2 mm, for example), the bed may not move at all when Z motor power is cut and Z axis resolution will increase (as maximum speed decreases). [...]
Some people think they want to do autoleveling, so they use multiple motors to drive Z axis screws. But it's actually the opposite- they have to do autoleveling because they used multiple motors. The screws get out of sync when the machine is powered up because there are multiple motors attached to them, and each motor jumps a little on power up. If the goal is to make youtube videos, autoleveling is OK, but it was more impressive a few years ago when the first one did it. Now there are lots of those videos and it's sort of "meh". If the goal is to make a printer that "just works" connecting all the screws to a single motor will keep them from ever getting out of sync so no autoleveling will be needed. You'll level the bed manually, one time, and never have to do it again unless you take the Z axis apart. If you have the funds to buy the extra motors, bed sensor, and controller expansion board, you could, instead, buy a flat bed plate and do without all the other junk and end up with a more reliable printer, probably for lower cost, definitely much simpler set-up, operation, and maintenance.
My corexy printer lifts the bed assembly with two belts driven by a single motor. The belts never get out of sync and the flat, tooling plate bed, never tilts. The machine "just works". The single, Z axis motor is driven directly by one of the drivers on the Duet board. It has a 30:1 worm gear reducer that prevents bed movement when the Z axis is powered down. I routinely transport the machine laying on its back (Z axis is 695mm) in my car or in a truck and when I get where I'm going, take the machine out, stand it back up and start printing without any adjustments.
Put a flat plate on a kinematic mount and lift it with a single motor. It's not hard to do...
Z won't bind because I am using a kinematic mount on which the bed is completely separable from the Z axis which is one of the reasons I am building tripple z in the first place.Quote
the_digital_dentist
Using ball screws almost guarantees the bed will drop, but will it drop equally at each screw? Unlikely. Differences in friction at each screw will probably cause the bed to tilt as it drops, maybe to the point that it will bind and stop the movement at some odd bed surface angle, long before it hits the bottom of the Z axis. When you next power up the Z axis, the motors will jump (which is the reason for using autoleveling). Will they jump in a way that releases the binding or enhances it? Will your autoleveling be working against the bed being wedged tightly, every time? Maybe you can apply EM braking to one of the motors to ensure higher friction at that screw and force the bed to tilt so it binds and never hits bottom...
Re: Brake vs. shorting stepper coils October 21, 2020 12:35PM |
Re: Brake vs. shorting stepper coils October 21, 2020 01:23PM |
Re: Brake vs. shorting stepper coils October 21, 2020 01:42PM |
Re: Brake vs. shorting stepper coils October 21, 2020 02:21PM |
Re: Brake vs. shorting stepper coils October 21, 2020 10:46PM |
Re: Brake vs. shorting stepper coils October 22, 2020 01:52AM |
You forgot to mention wobbly. For my other printer I need 450mm leadscrews TR8x2. For once they are hard to come by from a reputable source since the actual standard is either 4 start TR8 with 8mm lead or 1 start TR8 with 1.5mm lead (which makes some crooked positional accuracy number for a full step). For that printer I ordered 10 or so leadscrews because they all come from overseas they are either bend from the factory or bent during shipping. This was so frustrating and the reason why I went for ballscrews.Quote
dekutree64
If the bed is heavy enough to backdrive ballscrews, it's heavy enough to preload leadscrews. Use 'em. They're cheap, compact, and work just as well in this case. 1mm or 2mm lead.
Re: Brake vs. shorting stepper coils October 22, 2020 03:29AM |
Re: Brake vs. shorting stepper coils October 22, 2020 03:55AM |
Re: Brake vs. shorting stepper coils October 22, 2020 09:21AM |
Schild0r
So I could indeed use an allen wrench to reach through the trough hole in the build plate to the hex socket of the maggot screw to adjust the levelness of the build plate and retighten the counter nut. This would be tedious compared to a leveling knob but hopefully I would not have to do that often.
