Marling: steps for mm X different form Y
Posted by bissaorboea01
January 06, 2013 04:03AM
I'am a new to reprap and I have a problem that I hope sameone can solve.
I'm using a Marling on e prusa using Megatronics Board.
I set the Steps per mm in the following way:
#define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 200*16/1.25, 760*1.1} // default steps per unit for Prusa
When I print a square the X axis is correct but Y axis is longer by 10%.
The belt are tightened, I use the same alloy pulley, I dont use EPROM, the stepper motor work well and do not lose any steps, I tried to invert pololu X e Y with the same result...
Why this?
Re: Marling: steps for mm X different form Y
January 06, 2013 05:57AM
Very strange.
Are both belts the same type and make?
What happens if you swap the X & Y motor connections? (If you also swap the limit switches the machine will work but print mirror images). If X becomes the biggest then the problem is firmware / electronic. If it stays with Y then it is mechanical. If the pulleys have the same number of teeth then it must be different belt pitch.
January 06, 2013 10:10AM
Hi nophead,
I swaped X & Y motor connection and the rectangle have the same shape.
So it was is a mechanical problem:
I was using T2.5 pulley on 5cm belt.
Thanks Nophead!
January 06, 2013 10:38AM
How many teeth in your pulley?
