Bootloader doesn't burn out. Help!! July 26, 2012 06:51AM |
Re: Bootloader doesn't burn out. Help!! July 27, 2012 06:32AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Bootloader doesn't burn out. Help!! July 28, 2012 07:28AM |
Re: Bootloader doesn't burn out. Help!! July 29, 2012 06:56AM |
Re: Bootloader doesn't burn out. Help!! July 29, 2012 12:38PM |
avrdude -p m168 -c usbtiny -e -u -U lock:w:0x3f:m -U efuse:w:0x00:m -U hfuse:w:0xDD:m -U lfuse:w:0xFF:m avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.01s avrdude: Device signature = 0x1e9406 avrdude: erasing chip avrdude: reading input file "0x3f" avrdude: writing lock (1 bytes): Writing | ################################################## | 100% 0.00s avrdude: 1 bytes of lock written avrdude: verifying lock memory against 0x3f: avrdude: load data lock data from input file 0x3f: avrdude: input file 0x3f contains 1 bytes avrdude: reading on-chip lock data: Reading | ################################################## | 100% 0.00s avrdude: verifying ... avrdude: 1 bytes of lock verified avrdude: reading input file "0x00" avrdude: writing efuse (1 bytes): Writing | ################################################## | 100% 0.02s avrdude: 1 bytes of efuse written avrdude: verifying efuse memory against 0x00: avrdude: load data efuse data from input file 0x00: avrdude: input file 0x00 contains 1 bytes avrdude: reading on-chip efuse data: Reading | ################################################## | 100% 0.00s avrdude: verifying ... avrdude: 1 bytes of efuse verified avrdude: reading input file "0xDD" avrdude: writing hfuse (1 bytes): Writing | ################################################## | 100% 0.02s avrdude: 1 bytes of hfuse written avrdude: verifying hfuse memory against 0xDD: avrdude: load data hfuse data from input file 0xDD: avrdude: input file 0xDD contains 1 bytes avrdude: reading on-chip hfuse data: Reading | ################################################## | 100% 0.00s avrdude: verifying ... avrdude: 1 bytes of hfuse verified avrdude: reading input file "0xFF" avrdude: writing lfuse (1 bytes): Writing | ################################################## | 100% 0.02s avrdude: 1 bytes of lfuse written avrdude: verifying lfuse memory against 0xFF: avrdude: load data lfuse data from input file 0xFF: avrdude: input file 0xFF contains 1 bytes avrdude: reading on-chip lfuse data: Reading | ################################################## | 100% 0.00s avrdude: verifying ... avrdude: 1 bytes of lfuse verified avrdude done. Thank you.
avrdude -p m168 -c usbtiny -U flash:w:ATmegaBOOT_168_diecimila.hex -U lock:w:0x0f:m avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.02s avrdude: Device signature = 0x1e9406 avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "ATmegaBOOT_168_diecimila.hex" avrdude: input file ATmegaBOOT_168_diecimila.hex auto detected as Intel Hex avrdude: writing flash (16294 bytes): Writing | ################################################## | 100% 51.78s avrdude: 16294 bytes of flash written avrdude: verifying flash memory against ATmegaBOOT_168_diecimila.hex: avrdude: load data flash data from input file ATmegaBOOT_168_diecimila.hex: avrdude: input file ATmegaBOOT_168_diecimila.hex auto detected as Intel Hex avrdude: input file ATmegaBOOT_168_diecimila.hex contains 16294 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 29.46s avrdude: verifying ... avrdude: 16294 bytes of flash verified avrdude: reading input file "0x0f" avrdude: writing lock (1 bytes): Writing | ################################################## | 100% 0.02s avrdude: 1 bytes of lock written avrdude: verifying lock memory against 0x0f: avrdude: load data lock data from input file 0x0f: avrdude: input file 0x0f contains 1 bytes avrdude: reading on-chip lock data: Reading | ################################################## | 100% 0.00s avrdude: verifying ... avrdude: 1 bytes of lock verified avrdude: safemode: Fuses OK avrdude done. Thank you.
c:\>avrdude -c usbtiny -p m168 -U flash:w:extruder.cpp.hex avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.03s avrdude: Device signature = 0x1e9406 avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "extruder.cpp.hex" avrdude: input file extruder.cpp.hex auto detected as Intel Hex avrdude: writing flash (4744 bytes): Writing | ################################################## | 100% 3.06s avrdude: 4744 bytes of flash written avrdude: verifying flash memory against extruder.cpp.hex: avrdude: load data flash data from input file extruder.cpp.hex: avrdude: input file extruder.cpp.hex auto detected as Intel Hex avrdude: input file extruder.cpp.hex contains 4744 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 2.71s avrdude: verifying ... avrdude: 4744 bytes of flash verified avrdude: safemode: Fuses OK avrdude done. Thank you.
Re: Bootloader doesn't burn out. Help!! July 29, 2012 08:07PM |
but the temperatur is not reading and I cant control the extruder motor.
Re: Bootloader doesn't burn out. Help!! July 31, 2012 01:26PM |
Re: Bootloader doesn't burn out. Help!! August 01, 2012 06:43AM |
Is there a problem using a stepper motor whit 3 gen electronics and teacup firmware.
Re: Bootloader doesn't burn out. Help!! August 09, 2012 08:36AM |
