Marlin: Z Endstop 'follows' current Z position
June 01, 2013 03:18AM
Situation: The endstop point for Z axis keeps tracking its current position.
Example:
When I move Z to position 1.00, Z1.00 becomes the endstop position, and further movement in the negative direction triggers the endstop. If I then move Z to position 2.00, Z2.00 then becomes the new point at which endstop is triggered.
echo:endstops hit: Z:1.00
echo:endstops hit: Z:2.00
echo:endstops hit: Z:3.00
Basically the endstop point keeps tracking its current new Z position. M199 reports that th e z endstop is always triggered, even though the hardware is not. Hardware is not a problem as I have switched between X, Y, and Z endstop, and also have uploaded to 2 gen6.d electronic boards having the same problem.
SENDING:M119
Reporting endstop status
x_min: open
y_min: open
z_min: TRIGGERED
The firmware mechanical settings are shown below.
Please help. Thank you very much.
// corse Endstop Settings
//#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
// fine Enstop settings: Individual Pullups. will be ignord if ENDSTOPPULLUPS is defined
#define ENDSTOPPULLUP_XMAX
#define ENDSTOPPULLUP_YMAX
#define ENDSTOPPULLUP_ZMAX
#define ENDSTOPPULLUP_XMIN
#define ENDSTOPPULLUP_YMIN
#define ENDSTOPPULLUP_ZMIN
#endif
#ifdef ENDSTOPPULLUPS
#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
const bool Y_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
const bool Z_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
//#define DISABLE_MAX_ENDSTOPS
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false // For all extruders
#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops true //If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true //If true, axis won't move to coordinates greater than the defined lengths below.
// Travel limits after homing
#define X_MAX_POS 60
#define X_MIN_POS 0
#define Y_MAX_POS 1000
#define Y_MIN_POS 0
#define Z_MAX_POS 200
#define Z_MIN_POS 0
#define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS)
#define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS)
#define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
// The position of the homing switches
//#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used
//#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0)
//Manual homing switch locations:
#define MANUAL_X_HOME_POS 0
#define MANUAL_Y_HOME_POS 0
#define MANUAL_Z_HOME_POS 0
Re: Marlin: Z Endstop 'follows' current Z position
June 01, 2013 11:43PM
Just my 2 cents
i think its the last 3 lines in your file.
I don't have these in my config.h ( im using a Gen6d board) I would comment them out and try your system again. Im not sure what their purpose is.
Unrelated to your issue i noticed you have some weird travel limits
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
Seems to indicate your print bed is 60mm wide and 1 meter long ??? Surely that's impossible
June 02, 2013 12:49AM
Thank you for replying, bigfilsing.
bigfilsing Wrote:
> Just my 2 cents
I'm not sure what these does either. If anyone could please explain?
> weird travel limits
> #define X_MIN_POS 0
> #define Y_MIN_POS 0
> #define Z_MIN_POS 0
You're right. It is for my own testing to understand how it works (set different values to find out what whether it has effect on the actual movement).
Thanks!
June 02, 2013 04:57AM
to the best of my knowledge the define max and min are to limit the amount the software/firm ware can drive the steppers in any one direction
you wouldn't want it to be able to drive it beyond its physical limits . That's assuming you don't have MAX end stops.
So once each axis has been homed the firmware knows not to drive it further than the value you have assigned to MAX_POS ***
Edited 1 time(s). Last edit at 06/02/2013 08:45PM by bigfilsing.
June 03, 2013 02:44AM
if you're using mechanical endstops uncomment //#define DISABLE_MAX_ENDSTOPS try the m119 command without any being triggered what does it say? come back with that take it from there i had endstop problems but got it sorted now
