Is there a Marlin configuration setting for turning off the heated bed after finishing a SD-card job? The code seems to have a temperature shutdown, but autotempShutdown() seems to take care of the hotend only, not the bed included.
void autotempShutdown(){
#ifdef AUTOTEMP
if(autotemp_enabled)
autotemp_enabled=false;
if(degTargetHotend(active_extruder)>autotemp_min)
setTargetHotend(0,active_extruder);
#endif
I could add an extra line for the heated bed, but I wanted to make sure it is not implemented already by a setting I overlooked.
LE: I am already using the SD_FINISHED_RELEASECOMMAND to perform a command, so I would need another placeholder for the bed temperature shutdown.
Edited 1 time(s). Last edit at 06/23/2013 10:03AM by MPower.
