Repetier firmware - Extruder motor not responding confused smiley
July 03, 2013 07:40AM
I'm new to 3d printing and I just finished building my prusa i2.
I bought megatronics v2 electronics from reprapworld.
I tried to use marlin firmware as recomended but I couldnt connect with pronterface.. so I switched to repetier host and firmware
I managed to connect with the printer and manualy move X Y Z axis, but for some reason I cant control Extruder motor..
I did connect the motor cable into the E0 slot and pluged the stepstick into the corresponding slot..
I tried to connect the E motor to the X axis and it worked just fine.. so the problem isn't at the cable neither the motor..
I switched the stepsticks and nothing changed.. so I believe I am doing something wrong at the firmware configuration..
What I should check?
I included my configuration.h
Elias,
open | download - configuration.h.txt (48.5 KB)
Re: Repetier firmware - Extruder motor not responding confused smiley
July 08, 2013 08:27AM
Check pins.h, just to be sure:
#if MOTHERBOARD == 701
#define E0_STEP_PIN        35
#define E0_DIR_PIN         36
#define E0_ENABLE_PIN      34
Edited 1 time(s). Last edit at 07/08/2013 08:31AM by flurin.
July 08, 2013 08:55AM
Thanks for the answer.. I fixed it some days ago.. It needed to heat the extruder first..winking smiley
July 08, 2013 09:26AM
Ok, Did you change the Configuration.h file above?
I saw your setting MIN_EXTRUDER_TEMP = 0, so it should work with a cold extruder too.
/* \brief Minimum temperature for extruder operation
This is a saftey value. If your extruder temperature is below this temperature, no
extruder steps are executed. This is to prevent your extruder to move unless the fiament
is at least molten. After havong some complains that the extruder does not work, I leave
it 0 as default.
#define MIN_EXTRUDER_TEMP 0
July 08, 2013 09:47AM
I changed the pins in the extruder heater (pins.h) and after the heater worked .. I was able to move the motor...
September 14, 2014 04:45PM
This fixed a problem I have. Understanding the program and the willingness to share is a great thing, thanks
Ken
