Using pwm from servo signal to drive speed controller February 28, 2014 12:27AM |
Re: Using pwm from servo signal to drive speed controller February 28, 2014 09:28AM |
Re: Using pwm from servo signal to drive speed controller February 28, 2014 12:27PM |
Re: Using pwm from servo signal to drive speed controller February 28, 2014 05:07PM |
Re: Using pwm from servo signal to drive speed controller March 03, 2014 10:43PM |
Re: Using pwm from servo signal to drive speed controller March 03, 2014 11:45PM |
Re: Using pwm from servo signal to drive speed controller March 04, 2014 11:03PM |
Re: Using pwm from servo signal to drive speed controller March 05, 2014 08:39AM |
Re: Using pwm from servo signal to drive speed controller March 08, 2014 09:48AM |
Re: Using pwm from servo signal to drive speed controller March 09, 2014 12:17AM |
#if NUM_SERVOS > 0 case 601: int servo_index; int servo_position; if (code_seen('P')) servo_index = code_value(); if (code_seen('S')) { servo_position = code_value(); if ((servo_index >= 0) && (servo_index < NUM_SERVOS)) { servos[servo_index].attach(11); //11 is the set of servo pins closest to the reset button servos[servo_index].writeMicroseconds(700); //MIN pulse for speed controller delay(4000); servos[servo_index].writeMicroseconds(2000); //MAX pulse for speed controller delay(100); servos[servo_index].writeMicroseconds(700); delay(1000); servos[servo_index].writeMicroseconds(servo_position); } } break; #endif case 602: if (code_seen('P')) servo_index = code_value(); if ((servo_index >= 0) && (servo_index < NUM_SERVOS)) { servos[servo_index].detach(); } break;
Re: Using pwm from servo signal to drive speed controller March 09, 2014 01:30AM |
Re: Using pwm from servo signal to drive speed controller March 09, 2014 11:03AM |
Re: Using pwm from servo signal to drive speed controller March 09, 2014 02:00PM |
Re: Using pwm from servo signal to drive speed controller March 09, 2014 04:44PM |
Re: Using pwm from servo signal to drive speed controller March 09, 2014 06:06PM |
Re: Using pwm from servo signal to drive speed controller March 09, 2014 09:48PM |
Re: Using pwm from servo signal to drive speed controller March 09, 2014 10:15PM |
