X moves when homing Y
Posted by Arkaedra
August 08, 2014 01:39PM
Hello guys,
I just built my second printer, Marlin based. All the axis move correctly, the endstops work perfectly.
The error comes when I try to home the X or Y axis. Z axis just does correctly.
When I press home X axis, the Y axis do the home movement and viceversa!
I tried it with Pronterface and Repetier. I suppose that it's something firmware related but I haven't found any variable for that.
Does someone know how to proceed?
Regards
Re: X moves when homing Y
August 20, 2014 01:57AM
which electronics you are using ?
make sure that enstops are connected in correct sequence.
August 20, 2014 05:13AM
Are the motor connectors on the rampsboard in the right place, x on x and y on y?
August 20, 2014 08:42AM
It won't be where the end stops are connected. If you have the x and you end stops swapped, the correct axis will move, it will just crash through the endstop. More likely the motor connection. Although you say manual motion works correctly. There is no firmware setting for which axis homes with which command.
September 23, 2014 10:22AM
Thank you all of you for your support.
I discovered that the error was firmware related, all connections were OK, but homing all axes swaps the axes to control the travel of the extruders over the heat beda at the end of the printing process. This way the extruders don't hit a part of the printer.
Regards,
JoaquĆ­n.
