Duet- using end stops. and not stopping April 29, 2015 01:15AM |
Re: Duet- using end stops. and not stopping April 29, 2015 04:30AM |
Re: Duet- using end stops. and not stopping April 29, 2015 09:44PM |
Re: Duet- using end stops. and not stopping April 30, 2015 03:09AM |
Re: Duet- using end stops. and not stopping April 30, 2015 09:50PM |
DC42
Most microswitches have both normally open and normally closed contacts. The outer 2 of the 3 connections are usually the normally closed ones.
To use a normally open microswitch, use the M574 command to change the polarity to active high, see [reprap.org].
Re: Duet- using end stops. and not stopping May 01, 2015 05:13AM |
