Hotend fan pin controlled May 27, 2015 08:05PM |
Re: Hotend fan pin controlled May 28, 2015 10:19AM |
Re: Hotend fan pin controlled May 28, 2015 02:27PM |
Re: Hotend fan pin controlled May 29, 2015 07:39AM |
Re: Hotend fan pin controlled May 29, 2015 08:00AM |
Re: Hotend fan pin controlled May 29, 2015 11:42AM |
Re: Hotend fan pin controlled May 29, 2015 12:00PM |
Re: Hotend fan pin controlled May 29, 2015 01:58PM |
Yes, model cooler is usually on the D9 pin on the rampsQuote
So the "Extruder Cooler" is a different function from the default fan that cools the print itself ? Did I get you right?
I see. I thought of a bit different model. but thats fine. you need the active cooling and the liner, there are no ways around it.Quote
This is my clone
Yes correct.Quote
So I don't think PTFE inliners are a thing of the past.
You need something that translates the controlling function from the low powered logic pins to a 12V fan. There are some people trying to put LED strips in the printer with a similar controll mechanism, but there are some arguments against relay. The older boards dont have 12V switchting or PWM controlled pins besides heater1 and heater2/fan. and a controlled hotend fan is not necessary for most people.Quote
I don't like additional Mosfets laying around and as this basically an Arduino board with unused pins, I don't see the need for a Mosfet.
There will always be at least two unused endstops in any printer config and they work. With other pins you need to first find out their function. eg pin 0 and 1 have something todo with the serial connection i think, so they shouldn´t be used for this.Quote
There are so much pins on the board that I don't want to use endstop pins for this. When adding endstops in the near future, I will still have extruder endstop fins available but this is a dirty hack.
Possible but most likely a 5V pwm and even than I would bet on much amperage to play with.Quote
Okay .... So after playing around in the Repetier config tool I have found this:
Re: Hotend fan pin controlled May 30, 2015 04:06AM |
Please write shouldn´t or should not. You are confusing people with your bad english.Quote
sungod3k
There will always be at least two unused endstops in any printer config and they work. with other pins you need to first find out their function. eg pin 0 and 1 have something todo with the serial connection i think so they should be used for this.
