Duet Mendel90 and endstops June 03, 2015 01:50PM |
Re: Duet Mendel90 and endstops June 03, 2015 02:05PM |
Re: Duet Mendel90 and endstops June 04, 2015 10:12AM |
Re: Duet Mendel90 and endstops June 04, 2015 10:26AM |
Re: Duet Mendel90 and endstops June 04, 2015 12:19PM |
Re: Duet Mendel90 and endstops June 04, 2015 01:49PM |
yiancar
Question is this the correct way to set the Z offset ?(i mean in the homing file?)
yiancar
how do you do the simultaneous homing?
; Ormerod 1 homeall file for use with dc42 Duet firmware ; Adjust the bed upper and lower limits in config.g (M208 commands) to get the correct homing positions G91 G1 Z4 F200 G1 X-240 Y240 F3000 S1 G1 X4 Y-4 F600 G1 X-10 Y10 S1 G90 ... (z homing code follows)
Re: Duet Mendel90 and endstops June 04, 2015 02:31PM |
Re: Duet Mendel90 and endstops June 04, 2015 05:13PM |
yiancar
in the config.g i used M203 X15000 Y15000 Z100 E3600 it was the default i found in another config file. I really have no idea how to determine the proper value.
yiancar
How to I change to relative extrusion?
Re: Duet Mendel90 and endstops June 04, 2015 06:48PM |
Re: Duet Mendel90 and endstops June 05, 2015 04:05AM |
yiancar
An offtopic question, if i add a second extruder, how does the firmware know the distance between the 2 extruders in order to be able to print? is that something i add in slic3r?
M563 P0 D0 H1 ; Define tool 0 G10 P0 X-11 Y0 Z0 S0 R0 ; Set tool 0 offset, operating and standby temperatures M563 P1 D1 H2 ; Define tool 1 G10 P1 X11 Y0.4 Z0 S0 R0 ; Set tool 1 offset, operating and standby temperatures
