Hi there,
I was working with my printer mendel i2, mega and ramps 1.4 , and I realize that the axis needs to be calibrated, so I tried to work with arduino ide 1.0.5, opened my marlin version that works on my mega, and update the values of the calibration, then I tried to compile , and begins the nightmare.
I get the following errors
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::printFatDate(unsigned int)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:985: multiple definition of `SdBaseFile::printFatDate(unsigned int)'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:985: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile :: openRoot(SdVolume*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:890: multiple definition of `SdBaseFile
penRoot(SdVolume*)'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:890: first defined here
penCachedEntry(unsigned char, unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:740: multiple definition of `SdBaseFile
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:740: first defined here
penNext(SdBaseFile*, unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:791: multiple definition of `SdBaseFile
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:791: first defined here
pen(SdBaseFile*, unsigned int, unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:709: multiple definition of `SdBaseFile
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:709: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::rmRfStar()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:1392: multiple definition of `SdBaseFile::rmRfStar()'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:1392: first defined here
penParent(SdBaseFile*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:833: multiple definition of `SdBaseFile
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:833: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::lsPrintNext(unsigned char, unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:333: multiple definition of `SdBaseFile::lsPrintNext(unsigned char, unsigned char)'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:333: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::ls(unsigned char, unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:318: multiple definition of `SdBaseFile::ls(unsigned char, unsigned char)'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:318: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::fgets(char*, int, char*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:251: multiple definition of `SdBaseFile::fgets(char*, int, char*)'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:251: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::addCluster()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:32: multiple definition of `SdBaseFile::addCluster()'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:32: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::write(void const*, unsigned int)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:1729: multiple definition of `SdBaseFile::write(void const*, unsigned int)'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:1729: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::addDirCluster()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:48: multiple definition of `SdBaseFile::addDirCluster()'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:48: first defined here
pen(SdBaseFile*, unsigned char const*, unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:619: multiple definition of `SdBaseFile
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:619: first defined here
pen(SdBaseFile*, char const*, unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:584: multiple definition of `SdBaseFile
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:584: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::remove(SdBaseFile*, char const*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:1238: multiple definition of `SdBaseFile::remove(SdBaseFile*, char const*)'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:1238: first defined here
pen(char const*, unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:530: multiple definition of `SdBaseFile
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:530: first defined here
Marlin\SdBaseFile.cpp.o:C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:205: multiple definition of `SdBaseFile::cwd_'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:205: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:1443: multiple definition of `SdBaseFile:
dBaseFile(char const*, unsigned char)'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:1443: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::exists(char const*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:226: multiple definition of `SdBaseFile::exists(char const*)'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:226: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::mkdir(SdBaseFile*, unsigned char const*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:462: multiple definition of `SdBaseFile::mkdir(SdBaseFile*, unsigned char const*)'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:462: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::mkdir(SdBaseFile*, char const*, bool)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:428: multiple definition of `SdBaseFile::mkdir(SdBaseFile*, char const*, bool)'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:428: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::rename(SdBaseFile*, char const*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:1258: multiple definition of `SdBaseFile::rename(SdBaseFile*, char const*)'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:1258: first defined here
Marlin\SdBaseFile.cpp.o: In function `SdBaseFile::createContiguous(SdBaseFile*, char const*, unsigned long)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdBaseFile.cpp:150: multiple definition of `SdBaseFile::createContiguous(SdBaseFile*, char const*, unsigned long)'
SdBaseFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdBaseFile.cpp:150: first defined here
ldDateTime_'
Marlin\SdFatUtil.cpp.o: In function `SdFatUtil::FreeRam()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdFatUtil.cpp:29: multiple definition of `SdFatUtil::FreeRam()'
SdFatUtil.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdFatUtil.cpp:29: first defined here
Marlin\SdFatUtil.cpp.o: In function `print_P':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdFatUtil.cpp:50: multiple definition of `SdFatUtil::print_P(char const*)'
SdFatUtil.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdFatUtil.cpp:50: first defined here
erialPrint_P(char const*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdFatUtil.cpp:68: multiple definition of `SdFatUtil:
SdFatUtil.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdFatUtil.cpp:68: first defined here
Marlin\SdFatUtil.cpp.o: In function `SdFatUtil::println_P(char const*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdFatUtil.cpp:59: multiple definition of `SdFatUtil::println_P(char const*)'
SdFatUtil.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdFatUtil.cpp:59: first defined here
erialPrintln_P(char const*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdFatUtil.cpp:77: multiple definition of `SdFatUtil:
SdFatUtil.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdFatUtil.cpp:77: first defined here
Marlin\SdFile.cpp.o: In function `SdFile::write_P(char const*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdFile.cpp:81: multiple definition of `SdFile::write_P(char const*)'
SdFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdFile.cpp:81: first defined here
Marlin\SdFile.cpp.o: In function `SdFile::writeln_P(char const*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdFile.cpp:89: multiple definition of `SdFile::writeln_P(char const*)'
SdFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdFile.cpp:89: first defined here
Marlin\SdFile.cpp.o: In function `SdFile::write(char const*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdFile.cpp:74: multiple definition of `SdFile::write(char const*)'
SdFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdFile.cpp:74: first defined here
Marlin\SdFile.cpp.o: In function `SdFile::write(unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdFile.cpp:58: multiple definition of `SdFile::write(unsigned char)'
SdFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdFile.cpp:58: first defined here
Marlin\SdFile.cpp.o: In function `SdFile::write(void const*, unsigned int)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdFile.cpp:50: multiple definition of `SdFile::write(void const*, unsigned int)'
SdFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdFile.cpp:50: first defined here
Marlin\SdFile.cpp.o: In function `SdFile':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdFile.cpp:31: multiple definition of `SdFile:
dFile(char const*, unsigned char)'
SdFile.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdFile.cpp:31: first defined here
Marlin\SdVolume.cpp.o: In function `SdVolume::cacheFlush()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:108: multiple definition of `SdVolume::cacheFlush()'
SdVolume.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdVolume.cpp:108: first defined here
Marlin\SdVolume.cpp.o:C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:108: multiple definition of `SdVolume::cacheDirty_'
Marlin\SdVolume.cpp.o:C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:108: multiple definition of `SdVolume::cacheBlockNumber_'
Marlin\SdVolume.cpp.o:C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:108: multiple definition of `SdVolume::sdCard_'
Marlin\SdVolume.cpp.o:C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:108: multiple definition of `SdVolume::cacheBuffer_'
Marlin\SdVolume.cpp.o:C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:108: multiple definition of `SdVolume::cacheMirrorBlock_'
Marlin\SdVolume.cpp.o: In function `SdVolume::cacheRawBlock(unsigned long, bool)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:127: multiple definition of `SdVolume::cacheRawBlock(unsigned long, bool)'
SdVolume.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdVolume.cpp:127: first defined here
Marlin\SdVolume.cpp.o: In function `SdVolume::init(Sd2Card*, unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:324: multiple definition of `SdVolume::init(Sd2Card*, unsigned char)'
SdVolume.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdVolume.cpp:324: first defined here
Marlin\SdVolume.cpp.o: In function `SdVolume::freeClusterCount()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:280: multiple definition of `SdVolume::freeClusterCount()'
SdVolume.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdVolume.cpp:280: first defined here
Marlin\SdVolume.cpp.o: In function `SdVolume::fatPut(unsigned long, unsigned long)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:196: multiple definition of `SdVolume::fatPut(unsigned long, unsigned long)'
SdVolume.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdVolume.cpp:196: first defined here
Marlin\SdVolume.cpp.o: In function `SdVolume::fatGet(unsigned long, unsigned long*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:155: multiple definition of `SdVolume::fatGet(unsigned long, unsigned long*)'
SdVolume.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdVolume.cpp:155: first defined here
Marlin\SdVolume.cpp.o: In function `SdVolume::freeChain(unsigned long)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:255: multiple definition of `SdVolume::freeChain(unsigned long)'
SdVolume.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdVolume.cpp:255: first defined here
Marlin\SdVolume.cpp.o: In function `SdVolume::chainSize(unsigned long, unsigned long*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:141: multiple definition of `SdVolume::chainSize(unsigned long, unsigned long*)'
SdVolume.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdVolume.cpp:141: first defined here
Marlin\SdVolume.cpp.o: In function `SdVolume::allocContiguous(unsigned long, unsigned long*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/SdVolume.cpp:35: multiple definition of `SdVolume::allocContiguous(unsigned long, unsigned long*)'
SdVolume.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/SdVolume.cpp:35: first defined here
Marlin\stepper.cpp.o: In function `endstops_hit_on_purpose()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:210: multiple definition of `endstops_hit_on_purpose()'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:210: first defined here
Marlin\stepper.cpp.o: In function `enable_endstops':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:217: multiple definition of `enable_endstops(bool)'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:217: first defined here
Marlin\stepper.cpp.o: In function `st_wake_up()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:238: multiple definition of `st_wake_up()'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:238: first defined here
Marlin\stepper.cpp.o: In function `step_wait()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:244: multiple definition of `step_wait()'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:244: first defined here
Marlin\stepper.cpp.o: In function `st_init()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:774: multiple definition of `st_init()'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:774: first defined here
Marlin\stepper.cpp.o: In function `st_set_position(long const&, long const&, long const&, long const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:981: multiple definition of `st_set_position(long const&, long const&, long const&, long const&)'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:981: first defined here
.bss.count_position+0x0): multiple definition of `count_position'
stepper.cpp.o
.bss.count_position+0x0): first defined here
Marlin\stepper.cpp.o: In function `st_set_e_position(long const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:991: multiple definition of `st_set_e_position(long const&)'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:991: first defined here
Marlin\stepper.cpp.o: In function `st_get_position(unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:998: multiple definition of `st_get_position(unsigned char)'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:998: first defined here
Marlin\stepper.cpp.o: In function `quickStop()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:1028: multiple definition of `quickStop()'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:1028: first defined here
.bss.current_block+0x0): multiple definition of `current_block'
stepper.cpp.o
.bss.current_block+0x0): first defined here
Marlin\stepper.cpp.o: In function `digitalPotWrite(int, int)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:1191: multiple definition of `digitalPotWrite(int, int)'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:1191: first defined here
Marlin\stepper.cpp.o: In function `digipot_init':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:1214: multiple definition of `digipot_init()'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:1214: first defined here
Marlin\stepper.cpp.o: In function `digipot_current(unsigned char, int)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:1227: multiple definition of `digipot_current(unsigned char, int)'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:1227: first defined here
Marlin\stepper.cpp.o: In function `microstep_init':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:1249: multiple definition of `microstep_init()'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:1249: first defined here
Marlin\stepper.cpp.o: In function `serialprintPGM':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:1289: multiple definition of `microstep_readings()'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:1289: first defined here
Marlin\stepper.cpp.o: In function `microstep_ms(unsigned char, signed char, signed char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:1251: multiple definition of `microstep_ms(unsigned char, signed char, signed char)'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:1251: first defined here
Marlin\stepper.cpp.o: In function `microstep_mode(unsigned char, unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:1277: multiple definition of `microstep_mode(unsigned char, unsigned char)'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:1277: first defined here
Marlin\stepper.cpp.o: In function `blocks_queued':
/planner.h:157: multiple definition of `st_synchronize()'
stepper.cpp.o:/planner.h:157: first defined here
Marlin\stepper.cpp.o: In function `finishAndDisableSteppers()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:1017: multiple definition of `finishAndDisableSteppers()'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:1017: first defined here
Marlin\stepper.cpp.o: In function `__vector_17':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:315: multiple definition of `__vector_17'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:315: first defined here
.data.count_direction+0x0): multiple definition of `count_direction'
stepper.cpp.o
.data.count_direction+0x0): first defined here
.bss.endstops_trigsteps+0x0): multiple definition of `endstops_trigsteps'
stepper.cpp.o
.bss.endstops_trigsteps+0x0): first defined here
Marlin\stepper.cpp.o: In function `checkHitEndstops()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `checkHitEndstops()'
stepper.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/stepper.cpp:175: first defined here
.bss.endstops_stepsTotal+0x0): multiple definition of `endstops_stepsTotal'
stepper.cpp.o
.bss.endstops_stepsTotal+0x0): first defined here
.bss.endstops_stepsDone+0x0): multiple definition of `endstops_stepsDone'
stepper.cpp.o
.bss.endstops_stepsDone+0x0): first defined here
Marlin\temperature.cpp.o: In function `updatePID()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:320: multiple definition of `updatePID()'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:320: first defined here
.data.Ki+0x0): multiple definition of `Ki'
temperature.cpp.o
.data.Ki+0x0): first defined here
Marlin\temperature.cpp.o: In function `getHeaterPower(int)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:328: multiple definition of `getHeaterPower(int)'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:328: first defined here
.bss.soft_pwm_bed+0x0): multiple definition of `soft_pwm_bed'
temperature.cpp.o
.bss.soft_pwm_bed+0x0): first defined here
Marlin\temperature.cpp.o: In function `setWatch()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:905: multiple definition of `setWatch()'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:905: first defined here
Marlin\temperature.cpp.o: In function `disable_heater()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:974: multiple definition of `disable_heater()'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:974: first defined here
.bss.target_temperature+0x0): multiple definition of `target_temperature'
temperature.cpp.o
.bss.target_temperature+0x0): first defined here
.bss.target_temperature_bed+0x0): multiple definition of `target_temperature_bed'
temperature.cpp.o
.bss.target_temperature_bed+0x0): first defined here
Marlin\temperature.cpp.o: In function `scalePID_i(float)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:1371: multiple definition of `scalePID_i(float)'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:1371: first defined here
Marlin\temperature.cpp.o: In function `unscalePID_i(float)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:1376: multiple definition of `unscalePID_i(float)'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:1376: first defined here
Marlin\temperature.cpp.o: In function `scalePID_d(float)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:1381: multiple definition of `scalePID_d(float)'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:1381: first defined here
Marlin\temperature.cpp.o: In function `unscalePID_d(float)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:1386: multiple definition of `unscalePID_d(float)'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:1386: first defined here
Marlin\temperature.cpp.o: In function `bed_max_temp_error()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:1034: multiple definition of `bed_max_temp_error()'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:1034: first defined here
Marlin\temperature.cpp.o: In function `min_temp_error(unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:1019: multiple definition of `min_temp_error(unsigned char)'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:1019: first defined here
Marlin\temperature.cpp.o: In function `max_temp_error(unsigned char)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:1006: multiple definition of `max_temp_error(unsigned char)'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:1006: first defined here
Marlin\temperature.cpp.o: In function `__vector_22':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:1104: multiple definition of `__vector_22'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:1104: first defined here
.bss.current_temperature_raw+0x0): multiple definition of `current_temperature_raw'
temperature.cpp.o
.bss.current_temperature_raw+0x0): first defined here
.bss.current_temperature_bed_raw+0x0): multiple definition of `current_temperature_bed_raw'
temperature.cpp.o
.bss.current_temperature_bed_raw+0x0): first defined here
Marlin\temperature.cpp.o: In function `tp_init()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:705: multiple definition of `tp_init()'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:705: first defined here
.bss.current_temperature+0x0): multiple definition of `current_temperature'
temperature.cpp.o
.bss.current_temperature+0x0): first defined here
.bss.current_temperature_bed+0x0): multiple definition of `current_temperature_bed'
temperature.cpp.o
.bss.current_temperature_bed+0x0): first defined here
Marlin\temperature.cpp.o: In function `manage_heater()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:406: multiple definition of `manage_heater()'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:406: first defined here
.data.Kp+0x0): multiple definition of `Kp'
temperature.cpp.o
.data.Kp+0x0): first defined here
.data.Kd+0x0): multiple definition of `Kd'
temperature.cpp.o
.data.Kd+0x0): first defined here
Marlin\temperature.cpp.o: In function `PID_autotune(float, int, int)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/temperature.cpp:165: multiple definition of `PID_autotune(float, int, int)'
temperature.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/temperature.cpp:165: first defined here
.data.Kc+0x0): multiple definition of `Kc'
temperature.cpp.o
.data.Kc+0x0): first defined here
Marlin\ultralcd.cpp.o: In function `setTargetHotend':
/temperature.h:100: multiple definition of `lcd_cooldown()'
ultralcd.cpp.o:/temperature.h:100: first defined here
/temperature.h:100: multiple definition of `encoderPosition'
.data.currentMenu+0x0): multiple definition of `currentMenu'
ultralcd.cpp.o
.data.currentMenu+0x0): first defined here
Marlin\ultralcd.cpp.o: In function `lcd_reset_alert_level()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1311: multiple definition of `lcd_reset_alert_level()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1311: first defined here
/temperature.h:100: multiple definition of `lcd_status_message_level'
Marlin\ultralcd.cpp.o: In function `lcd_buzz(long, unsigned int)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1412: multiple definition of `lcd_buzz(long, unsigned int)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1412: first defined here
Marlin\ultralcd.cpp.o: In function `lcd_clicked()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1416: multiple definition of `lcd_clicked()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1416: first defined here
/temperature.h:100: multiple definition of `buttons'
Marlin\ultralcd.cpp.o: In function `itostr2(unsigned char const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1430: multiple definition of `itostr2(unsigned char const&)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1430: first defined here
/temperature.h:100: multiple definition of `conv'
Marlin\ultralcd.cpp.o: In function `ftostr31(float const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1441: multiple definition of `ftostr31(float const&)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1441: first defined here
Marlin\ultralcd.cpp.o: In function `ftostr31ns(float const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1456: multiple definition of `ftostr31ns(float const&)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1456: first defined here
Marlin\ultralcd.cpp.o: In function `ftostr32(float const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1470: multiple definition of `ftostr32(float const&)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1470: first defined here
Marlin\ultralcd.cpp.o: In function `itostr31(int const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1487: multiple definition of `itostr31(int const&)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1487: first defined here
Marlin\ultralcd.cpp.o: In function `itostr3(int const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1499: multiple definition of `itostr3(int const&)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1499: first defined here
Marlin\ultralcd.cpp.o: In function `ftostr3(float const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1425: multiple definition of `ftostr3(float const&)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1425: first defined here
Marlin\ultralcd.cpp.o: In function `itostr3left(int const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1514: multiple definition of `itostr3left(int const&)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1514: first defined here
Marlin\ultralcd.cpp.o: In function `itostr4(int const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1537: multiple definition of `itostr4(int const&)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1537: first defined here
Marlin\ultralcd.cpp.o: In function `ftostr5(float const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1557: multiple definition of `ftostr5(float const&)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1557: first defined here
Marlin\ultralcd.cpp.o: In function `ftostr51(float const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1582: multiple definition of `ftostr51(float const&)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1582: first defined here
Marlin\ultralcd.cpp.o: In function `ftostr52(float const&)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1598: multiple definition of `ftostr52(float const&)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1598: first defined here
/temperature.h:100: multiple definition of `lcd'
Marlin\ultralcd.cpp.o: In function `lcd_buttons_update()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1324: multiple definition of `lcd_buttons_update()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1324: first defined here
/temperature.h:100: multiple definition of `blocking_enc'
/temperature.h:100: multiple definition of `lastEncoderBits'
/temperature.h:100: multiple definition of `encoderDiff'
.data.lcd_status_message+0x0): multiple definition of `lcd_status_message'
ultralcd.cpp.o
.data.lcd_status_message+0x0): first defined here
.data.lcdDrawUpdate+0x0): multiple definition of `lcdDrawUpdate'
ultralcd.cpp.o
.data.lcdDrawUpdate+0x0): first defined here
/temperature.h:100: multiple definition of `currentMenuViewOffset'
/temperature.h:100: multiple definition of `move_menu_scale'
/temperature.h:100: multiple definition of `lcd_status_update_delay'
/temperature.h:100: multiple definition of `prevMenu'
/temperature.h:100: multiple definition of `prevEncoderPosition'
Marlin\ultralcd.cpp.o: In function `menu_edit_float5()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1039: multiple definition of `menu_edit_float5()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1039: first defined here
/temperature.h:100: multiple definition of `editLabel'
/temperature.h:100: multiple definition of `editValue'
/temperature.h:100: multiple definition of `minEditValue'
/temperature.h:100: multiple definition of `maxEditValue'
Marlin\ultralcd.cpp.o: In function `menu_edit_float3()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1037: multiple definition of `menu_edit_float3()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1037: first defined here
Marlin\ultralcd.cpp.o: In function `menu_edit_float52()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1041: multiple definition of `menu_edit_float52()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1041: first defined here
Marlin\ultralcd.cpp.o: In function `menu_edit_callback_long5()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1042: multiple definition of `menu_edit_callback_long5()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1042: first defined here
/temperature.h:100: multiple definition of `callbackFunc'
Marlin\ultralcd.cpp.o: In function `menu_edit_float51()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1040: multiple definition of `menu_edit_float51()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1040: first defined here
/temperature.h:100: multiple definition of `absPreheatFanSpeed'
Marlin\ultralcd.cpp.o: In function `menu_edit_int3()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1036: multiple definition of `menu_edit_int3()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1036: first defined here
/temperature.h:100: multiple definition of `absPreheatHotendTemp'
/temperature.h:100: multiple definition of `absPreheatHPBTemp'
/temperature.h:100: multiple definition of `plaPreheatFanSpeed'
/temperature.h:100: multiple definition of `plaPreheatHotendTemp'
/temperature.h:100: multiple definition of `plaPreheatHPBTemp'
Marlin\ultralcd.cpp.o: In function `lcd_implementation_drawedit(char const*, char*)':
/ultralcd_implementation_hitachi_HD44780.h:608: multiple definition of `lcd_implementation_drawedit(char const*, char*)'
ultralcd.cpp.o:/ultralcd_implementation_hitachi_HD44780.h:608: first defined here
Marlin\ultralcd.cpp.o: In function `menu_edit_long5()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1042: multiple definition of `menu_edit_long5()'
Marlin\ultralcd.cpp.o: In function `menu_edit_callback_float52()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1041: multiple definition of `menu_edit_callback_float52()'
Marlin\ultralcd.cpp.o: In function `menu_edit_callback_float51()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1040: multiple definition of `menu_edit_callback_float51()'
Marlin\ultralcd.cpp.o: In function `menu_edit_callback_float5()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1039: multiple definition of `menu_edit_callback_float5()'
Marlin\ultralcd.cpp.o: In function `menu_edit_callback_float32()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1038: multiple definition of `menu_edit_callback_float32()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1038: first defined here
Marlin\ultralcd.cpp.o: In function `menu_edit_float32()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1038: multiple definition of `menu_edit_float32()'
Marlin\ultralcd.cpp.o: In function `menu_edit_callback_float3()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1037: multiple definition of `menu_edit_callback_float3()'
Marlin\ultralcd.cpp.o: In function `menu_edit_callback_int3()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1036: multiple definition of `menu_edit_callback_int3()'
/temperature.h:100: multiple definition of `raw_Ki'
/temperature.h:100: multiple definition of `raw_Kd'
Marlin\ultralcd.cpp.o: In function `copy_and_scalePID_i()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1615: multiple definition of `copy_and_scalePID_i()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1615: first defined here
Marlin\ultralcd.cpp.o: In function `copy_and_scalePID_d()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1625: multiple definition of `copy_and_scalePID_d()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1625: first defined here
Marlin\ultralcd.cpp.o: In function `lcd_setstatuspgm(char const*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1294: multiple definition of `lcd_setstatuspgm(char const*)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1294: first defined here
Marlin\ultralcd.cpp.o: In function `lcd_setalertstatuspgm(char const*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1301: multiple definition of `lcd_setalertstatuspgm(char const*)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1301: first defined here
Marlin\ultralcd.cpp.o: In function `lcd_setstatus(char const*)':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1287: multiple definition of `lcd_setstatus(char const*)'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1287: first defined here
Marlin\ultralcd.cpp.o: In function `lcd_update()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1184: multiple definition of `lcd_update()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1184: first defined here
/temperature.h:100: multiple definition of `lcd_oldcardstatus'
/temperature.h:100: multiple definition of `lcd_next_update_millis'
Marlin\ultralcd.cpp.o: In function `lcd_init()':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:1131: multiple definition of `lcd_init()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:1131: first defined here
Marlin\ultralcd.cpp.o: In function `setTargetBed':
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:499: multiple definition of `lcd_preheat_abs_bedonly()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:499: first defined here
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:491: multiple definition of `lcd_preheat_pla_bedonly()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:491: first defined here
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:418: multiple definition of `lcd_preheat_abs0()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:418: first defined here
C:\Documents and Settings\FGR\Mis documentos\Arduino\libraries\Marlin/ultralcd.cpp:409: multiple definition of `lcd_preheat_pla0()'
ultralcd.cpp.o:C:\DOCUME~1\FGR\CONFIG~1\Temp\build8466897382412100899.tmp/ultralcd.cpp:409: first defined here
The last time I updated the firmware, I didn't receive any errors, and I didn't change anything,
somebody knows what happen?
I can't eliminate the smileys, sorry for that
