New RepRapFirmware 1.09i-dc42 for Duet electronics September 02, 2015 02:54PM |
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 02, 2015 03:12PM |
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 03, 2015 03:02PM |
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 03, 2015 04:30PM |
Re: New RepRapFirmware 1.09j-dc42 for Duet electronics September 06, 2015 09:18AM |
Re: New RepRapFirmware 1.09j-dc42 for Duet electronics September 06, 2015 10:03AM |
Great! I was following your blog entry [miscsolutions.wordpress.com] and entered "M558 P1" when setting IR probe... causing a crash on the next homing. Now it's safe.Quote
dc42
* M574 endstop configuration now overrides M558 when determining whether or not to use the Z probe instead of a homing switch
Re: New RepRapFirmware 1.09j-dc42 for Duet electronics September 06, 2015 10:37AM |
pkm
dc42
Re: New RepRapFirmware 1.09j-dc42 for Duet electronics September 07, 2015 01:29PM |
Re: New RepRapFirmware 1.09j-dc42 for Duet electronics September 07, 2015 03:51PM |
Re: New RepRapFirmware 1.09j-dc42 for Duet electronics September 07, 2015 06:13PM |
llamatrails
Seeing this error, version 1.09j :
Error: SetPositions called when DDA ring not empty
Rick
Re: New RepRapFirmware 1.09j-dc42 for Duet electronics September 08, 2015 07:14PM |
Re: New RepRapFirmware 1.09j-dc42 for Duet electronics September 09, 2015 03:34AM |
Re: New RepRapFirmware 1.09j-dc42 for Duet electronics September 09, 2015 08:32AM |
dc42
Thanks, Rick. I figured out what change I made in 1.09j that is causing that message, and I'll fix it in 1.09i.
The object height is showing as 200mm because of the G1 Z200 command in your end gcode. Try changing it to G0 Z200, or remove it altogether as you already have a G28 to move the head away from the print.
Re: New RepRapFirmware 1.09j-dc42 for Duet electronics September 09, 2015 09:56AM |
llamatrails
dc42
Appreciate the hard work. Moving from Arduino/RAMPS and using your IR sensor has simplified printing sooo much !!!
Rick
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 12, 2015 12:33PM |
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 12, 2015 02:56PM |
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 12, 2015 03:27PM |
dc42
If you are getting different X and Y sizes, yet the auto calibration is giving you the correct heights all over the bed, then I think there is something significant is wrong with your build. I suspect that you may find that your X:Y size ratio may depend on the size of the print you do and/or the position of the print on the bed. You could try printing calibration cubes of different sizes, and at different places on the bed. Any adjustment you make to the tower positions to correct the X:Y size ratio is going to have an adverse effect on the flatness of the printing plane.
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 12, 2015 04:35PM |
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 13, 2015 04:18AM |
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 13, 2015 05:27AM |
dc42
I suspect the problem you are having with XY ratio not being correct is due to backlash in your joints, or one pair of diagonal rods having unequal spacings at the upper and lower ends, or diagonal rods being not quite the same lengths, or something similar.
dc42
Any correction you make to tower positions to compensate so as to get equal XY sizes will have an adverse effect on bed flatness.
dc42
Did you ever try printing calibration spirals when you were using Marlin?
dc42
Did you try printing calibration cubes of different sizes and at different places on the bed, to make sure that the XY ratio was correct everywhere?
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 13, 2015 05:39AM |
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 13, 2015 05:47AM |
pkm
Koenig
I agree with David here. Angular positions + delta radius + origin shift is identical to tower offsets + delta radius.
But nevertheless you don't get the result. I would try another set of calibration points, different number of points etc.
dc42
I have considered adding M665 parameters to allow the origin to be translated, in order to support delta printers with deliberately usual geometries. However, placing the origin at the centre fo the circle that the towers lies on work for both both standard and 'square' deltas, so I haven't done this yet.
Doesn't angular offsets just move the towers along the same perimeter of a perfect circle?
what happens to the math if you put one of the towers slightly inside or outside of that perimeter?
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 13, 2015 06:29AM |
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 13, 2015 07:03AM |
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 13, 2015 07:18AM |
pkm
Koenig
I mean changing the points in bed.g file. Put them in a square vertices instead of a triangle/hexagon etc. That might improve the calibration. Or not. Still worth trying.
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 13, 2015 07:37AM |
3didd
Any chance I can ask if the 1.09j Raw Firmware files are available for download.
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 13, 2015 10:00AM |
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 13, 2015 10:21AM |
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 13, 2015 12:11PM |
dc42
In response to more than one post above:
1. If you want to achieve the effect of moving the X tower a little closer to the centre, you can achieve that as follows. Your towers form an isosceles triangle instead of an equilateral one, with the base longer than the sides. So apply a negative correction angle to the Y tower, and a positive angle correction of equal magnitude to the Z tower. [Alternatively, leave the Z tower alone, apply a negative correction to the X tower, and a negative correction of twice the amount to the Y tower.] Then reduce the delta radius slightly. You can use school trigonometry to work out the size of the corrections you need. You will also get an origin shift of somewhat less than the amount you have moved the X tower inwards.
dc42
2. I didn't call anyone stupid. Even clever people occasionally do stupid things, especially when haven't worked out what the problem they are trying to solve really is.
Re: New RepRapFirmware 1.09i-dc42 for Duet electronics September 13, 2015 05:04PM |
