Other Firmware On Smoothieboard September 08, 2015 10:35PM |
Re: Other Firmware On Smoothieboard September 09, 2015 02:23PM |
Re: Other Firmware On Smoothieboard September 09, 2015 03:00PM |
Re: Other Firmware On Smoothieboard September 09, 2015 03:59PM |
ElmoC
The fact the the firmware continues to allow movement in the direction of an end stop, even though the end stop is triggered.
ElmoC
I busted an end stop because of that. Then when I decided to try and replace the end stop with a sensor that could be used for both and end stop and a probe, have been told it can't do that.
ElmoC
The SD card is mounted by default even though the documentation states all over the place about having to unmount the card to prevent problems.
ElmoC
You have to replace the firmware. And even when you have the SD card mounted, the speed is painfully slow.
ElmoC
And in regards to the probe use, there is this big red warning about the SD card and the probe.
ElmoC
I have to power cycle the printer repeatedly to get the LCD panel to come up correctly. Never had this problem when I used the panel on other controllers.
ElmoC
The temperature switch module only keys of the tool's letter, not the ID.
ElmoC
These have been some of the biggest issues I have had with it. The probe/end stop issue became the deal breaker with the firmware. I have no issues with the hardware itself. Just the firmware.
Re: Other Firmware On Smoothieboard September 09, 2015 06:55PM |
arthurwolf
ElmoC
While I do not remember off-hand, I know there is an easy fix to this. Maybe do a search in the forums for it.
Re: Other Firmware On Smoothieboard September 09, 2015 07:00PM |
vreihen
arthurwolf
ElmoC
The only time that I've seen problems with a GLCD refusing to start up or displaying gibberish was when the 5V was too weak. If configured for on-board 5V power, did you use a 1.0A voltage regulator or only the 0.5A one?????
Re: Other Firmware On Smoothieboard September 09, 2015 07:35PM |
arthurwolf
...( I heard somebody say Duet actually uses SPIO to access the SD card, which would be nice if it is true, maybe dc42 can comment on this.
Re: Other Firmware On Smoothieboard September 10, 2015 06:16AM |
dc42
arthurwolf
The Duet uses the Atmel HSMCI interface. I don't know a lot about it, but according to the datasheet, "The High Speed Multimedia Card Interface (HSMCI) supports the MultiMedia Card (MMC) Specification V4.3, the SD Memory Card Specification V2.0, the SDIO V2.0 specification and CE-ATA V1.1.". The bus is 4 data bits plus 3 control lines wide, and the clock rate is up to 42MHz.
Re: Other Firmware On Smoothieboard September 10, 2015 08:15AM |
Re: Other Firmware On Smoothieboard September 10, 2015 08:17AM |
dc42
[Off topic] Talking of Smoothie 2, any chance you can increase the values of the pullup resistors on the endstop inputs? My IR Z probe board has resistors in series with the output, and this is fine with the pullup resistors on most boards, but the low value (1K) pullup on the Smoothie is too low for it. I don't want to use lower value output resistors, because they protect the board when the user plugs in the board the wrong way round, thereby putting 5V into the output pin. The effective output resistance of the sensor board is 1.64K.
I wouldn't be surprised if some opto endstops have problems with 1k pullup resistors too. They may not be designed to sink 5mA when active. It's the same with most Hall sensor chips that work down to 3.3V.
Re: Other Firmware On Smoothieboard December 01, 2016 11:24AM |
Re: Other Firmware On Smoothieboard December 01, 2016 11:26AM |
Re: Other Firmware On Smoothieboard December 01, 2016 11:37AM |
Re: Other Firmware On Smoothieboard December 01, 2016 11:41AM |
Re: Other Firmware On Smoothieboard December 02, 2016 03:13PM |
arthurwolf
We are working on several web interface projects that would be much better than anything around at this point, but those are huge projects that are still going to take time. Several OSHW companies are involved in contributing to that work, it's really going to be spectacular.
In the meantime the interfaces you can install to your SD card using the link above are a nice step up from the current "basic" interface ( which was never intended as anything but an example for the community to improve on )
Re: Other Firmware On Smoothieboard December 02, 2016 03:24PM |
Re: Other Firmware On Smoothieboard December 02, 2016 03:28PM |
Calvinx66
Sadly that's just words and can be considered vaporware.
Calvinx66
And I'm sorry to say this but i do notice that where Smoothie is concerned it's always if and but's and the key words with Smoothie are "in the future" and about how huge a project it is.
Calvinx66
Tomorrow never really comes
Calvinx66
As for clunky. It's everything. Trying to do anything is a chore in the same way as its a pain in the ass changing things in marlin via arduino
Calvinx66
Playing with simple stuff that you never give a second thought doing using a duet and it's web interface brings a sigh of frustration when having to do the same with a Smoothie.
Calvinx66
Using the software in the link posted is akin to watching someone wheelchair bound attempting to climb mount everest.
Re: Other Firmware On Smoothieboard December 02, 2016 03:30PM |
ElmoC
Has soft end stops been implemented yet?
Re: Other Firmware On Smoothieboard November 21, 2017 02:11PM |
