suggested addition to the dc42 firmware October 26, 2015 11:47PM |
Re: suggested addition to the dc42 firmware October 26, 2015 11:58PM |
Re: suggested addition to the dc42 firmware October 27, 2015 04:04AM |
Re: suggested addition to the dc42 firmware October 27, 2015 05:16AM |
M561 ; clear any bed transform, otherwise homing may be at the wrong height G31 X0 Y0 ; don't want any probe offset for this
Re: suggested addition to the dc42 firmware October 27, 2015 05:59AM |
o_lampe
Should I recalculate the probe points manually or reduce them to fit the bed?
-Olaf
Re: suggested addition to the dc42 firmware October 27, 2015 11:28AM |
Re: suggested addition to the dc42 firmware October 27, 2015 12:41PM |
Re: suggested addition to the dc42 firmware October 27, 2015 01:40PM |
shadowphile
oops, used to relying on the Autocalibrate button, thanks.
Also, my mistake, I already use 6 factor. I meant the arm radius. Normally one manually puts that in but your routine calculates it out. Bed curvature will not be detected as precisely if the probe region has a small diameter compared to the frame size, which means the XY print dimensions will have a larger error. Am I wrong?
