Guide me with Marlin firmware and full graphic LCD November 14, 2015 11:20AM |
Re: Guide me with Marlin firmware and full graphic LCD November 14, 2015 12:02PM |
Re: Guide me with Marlin firmware and full graphic LCD November 14, 2015 01:03PM |
Re: Guide me with Marlin firmware and full graphic LCD November 14, 2015 02:24PM |
Re: Guide me with Marlin firmware and full graphic LCD November 14, 2015 02:58PM |
Re: Guide me with Marlin firmware and full graphic LCD November 14, 2015 03:22PM |
Re: Guide me with Marlin firmware and full graphic LCD November 14, 2015 07:22PM |
Re: Guide me with Marlin firmware and full graphic LCD November 15, 2015 01:36AM |
Re: Guide me with Marlin firmware and full graphic LCD November 15, 2015 12:04PM |
Re: Guide me with Marlin firmware and full graphic LCD November 15, 2015 01:58PM |
Re: Guide me with Marlin firmware and full graphic LCD November 15, 2015 03:42PM |
Re: Guide me with Marlin firmware and full graphic LCD November 15, 2015 04:10PM |
Re: Guide me with Marlin firmware and full graphic LCD November 15, 2015 04:46PM |
Sure you can. You will get the boot message and see some parameters. You need to make sure that the baud rate in pronterface is the one you configured in Marlin.Quote
Can I just upload and connect the usb and use pronterface but WITHOUT ramps?
Verbinde... start Drucker ist jetzt Online. echo:Marlin 1.0.3 dev echo: Last Updated: Nov 14 2015 20:17:17 | Author: (none, default config) Compiled: Nov 14 2015 echo: Free Memory: 3498 PlannerBufferBytes: 1232 echo:Hardcoded Default Settings Loaded echoteps per unit: echo: M92 X105.70 Y107.20 Z4000.00 E795.00 echo:Maximum feedrates (mm/s): echo: M203 X200.00 Y200.00 Z3.00 E35.00 echo:Maximum Acceleration (mm/s2): echo: M201 X5000 Y5000 Z100 E5000 echo:Accelerations: P=printing, R=retract and T=travel echo: M204 P1000.00 R1500.00 T1500.00 echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00 echo:Home offset (mm): echo: M206 X0.00 Y0.00 Z0.00 echoID settings: echo: M301 P17.20 I1.64 D45.24 echo:Filament settings: Disabled echoD init fail Error:Heated bed switched off. MAXTEMP triggered !! Errorrinter stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
Re: Guide me with Marlin firmware and full graphic LCD November 22, 2015 12:27PM |
Re: Guide me with Marlin firmware and full graphic LCD November 23, 2015 10:12AM |
Re: Guide me with Marlin firmware and full graphic LCD November 27, 2015 02:02PM |
Re: Guide me with Marlin firmware and full graphic LCD November 27, 2015 02:06PM |
Re: Guide me with Marlin firmware and full graphic LCD November 27, 2015 06:23PM |
Re: Guide me with Marlin firmware and full graphic LCD November 28, 2015 12:27AM |
Re: Guide me with Marlin firmware and full graphic LCD November 28, 2015 09:23AM |
Re: Guide me with Marlin firmware and full graphic LCD March 04, 2019 02:03PM |
Re: Guide me with Marlin firmware and full graphic LCD March 04, 2019 07:57PM |
Admin Registered: 13 years ago Posts: 7,002 |
