Minor gripe with the RepRapFirmare and/or the website for Duet January 09, 2016 11:40AM |
Re: Minor gripe with the RepRapFirmare and/or the website for Duet January 09, 2016 02:27PM |
Re: Minor gripe with the RepRapFirmare and/or the website for Duet January 09, 2016 04:11PM |
Re: Minor gripe with the RepRapFirmare and/or the website for Duet January 10, 2016 05:34AM |
M104 S0 ; turn off hot-end M140 S0 ; turn off bed M107 ; Turn off fan M83 ; relative mode G1 E-1 ; reduce filament pressure M82 ; absolute mode G1 X0 Y0 Z240 ; home X & Y, drop the print bed M84 ; disable motorsI have attached a couple of screenshots; the first shows the interface just as the very last nozzle moves were being made - note the Time Left value was 00s, and the blue progress bar was showing 2.3%. The second screenshot taken a couple of seconds later when the printbed had reached 240mm (lowest position) - note the blue progress bar showing 100%. Both show an object height of 240mm.
Re: Minor gripe with the RepRapFirmare and/or the website for Duet January 10, 2016 10:10AM |
Re: Minor gripe with the RepRapFirmare and/or the website for Duet January 11, 2016 06:29AM |
Re: Minor gripe with the RepRapFirmare and/or the website for Duet January 11, 2016 07:20PM |
Re: Minor gripe with the RepRapFirmare and/or the website for Duet January 12, 2016 10:51AM |
Re: Minor gripe with the RepRapFirmare and/or the website for Duet January 12, 2016 12:00PM |
G1 E-10 F2400 G91 G1 Z5 F360 G90 G1 X0 Y0 F6000 M107 M0
Re: Minor gripe with the RepRapFirmare and/or the website for Duet January 15, 2016 03:24PM |
chrishamm
The main reason the progress bar and the end-time estimations don't work properly is because your G-code does not contain any comments. Which slicer did you use to generate that one? I'd check if there is an option to enable them so that the filament usage can be used.
As for the object height detection, the easiest way to prevent the firmware from parsing an additonal lift is to encapsulate the individual lift movement via G90/G91 as I do in my end G-Code:
HTH!
Re: Minor gripe with the RepRapFirmare and/or the website for Duet January 16, 2016 10:42AM |
chrishamm
HTH!
Re: Minor gripe with the RepRapFirmare and/or the website for Duet January 16, 2016 11:03AM |
Re: Minor gripe with the RepRapFirmare and/or the website for Duet January 22, 2016 10:11AM |
