Duet - RepRapFirmware - Z min endstop ignored August 06, 2016 07:47PM |
M119 Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stoppedand
M119 Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: not stopped
M574 Endstop configuration: X low end (active low), Y low end (active low), Z low end (active low), E (active high)
; Movement section M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it) M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes forwards M558 P0 X0 Y0 Z0 ; disable z-probe M574 X1 Y1 Z1 S0 ; set endstop configuration (X and Y endstops only, at low end, active high) M906 X800 Y800 Z900 E1000 ; Set motor currents (mA) M201 X800 Y800 Z100 E1000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z10000 E3600 ; Maximum speeds (mm/min) M566 X600 Y600 Z100 E20 ; Minimum speeds mm/minute M208 X200 Y200 Z200 ; set axis maxima (adjust to suit your machine) M208 X-20 Y0 Z-0.2 S1 ; set axis minimum (adjust to make X=0 and Y=0 the edge of the bed) M92 X99.9685 Y99.9685 Z201.2400 ; Set axis steps/mm M92 E49.27 ; Set extruder steps per mm G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves
Firmware Name: RepRapFirmware for Duet Firmware Version: 1.15-beta3 (2016-07-09)
Re: Duet - RepRapFirmware - Z min endstop ignored August 07, 2016 02:39AM |
Re: Duet - RepRapFirmware - Z min endstop ignored August 07, 2016 12:24PM |
G1 X-1 F1000 S1Pushing the X-min-endstop halts further movement as I'd expect.
Re: Duet - RepRapFirmware - Z min endstop ignored August 08, 2016 02:07AM |
