Teacup on Arduino Nano problem in upload (Solved)
May 06, 2017 05:24PM
Hi
i am trying to upload teacup in arduino Nano but have no luck with that..
from the board section i have choose cnc shiled v3 and for cpu the atmega 328p
in the ''edit / settings'' i choose the ''arduino'' for AVR Programmer as the standard stk500 was giving me always error with : time out connection
the problem is that when i am trying tou upload it in a Arduino Nano board it tries to connect but nothing happen
avrdude -c arduino  -b 115200 -p atmega328p -P /dev/ttyUSB0 -U flash:w:"/home/caslor/Downloads/TEACUPFirmWares/Teacup_Firmware-master/teacup.hex":i
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
RC = 1 - Build terminated
Upload terminated abnormally.
when i choose to upload in an Arduino UNO board then everything going well
avrdude -c arduino  -b 115200 -p atmega328p -P /dev/ttyUSB1 -U flash:w:"/home/caslor/Downloads/TEACUPFirmWares/Teacup_Firmware-master/teacup.hex":i
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/home/caslor/Downloads/TEACUPFirmWares/Teacup_Firmware-master/teacup.hex"
avrdude: writing flash (17308 bytes):
Writing | ################################################## | 100% 2.74s
avrdude: 17308 bytes of flash written
avrdude: verifying flash memory against /home/caslor/Downloads/TEACUPFirmWares/Teacup_Firmware-master/teacup.hex:
avrdude: load data flash data from input file /home/caslor/Downloads/TEACUPFirmWares/Teacup_Firmware-master/teacup.hex:
avrdude: input file /home/caslor/Downloads/TEACUPFirmWares/Teacup_Firmware-master/teacup.hex contains 17308 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 2.14s
avrdude: verifying ...
avrdude: 17308 bytes of flash verified
Upload completed normally.
what am i doing wrong ?
thanks in advance
Edited 1 time(s). Last edit at 05/08/2017 07:16AM by caslor.
Re: Teacup on Arduino Nano problem in upload
May 07, 2017 09:01AM
Could be the baudrate. I'm not 100% sure, but try 57600.
May 07, 2017 06:39PM
Wurstnase
Wow !!! you are my saver smiling smiley
that was the problem smiling smiley
when i changed the Baudrate in teacup edit/settings from 115200 to 57600 , problem solved
Thanks for the help
May 08, 2017 01:10AM
You're welcome smileys with beer
Edited 1 time(s). Last edit at 05/08/2017 01:10AM by Wurstnase.
