Dual Z drivers MARLIN/RAMPS (MKS Base 1.5)
July 29, 2017 01:36PM
I have dual Z-axes that I want to have discreet drivers for. I have wired up the second Z axis to E1. I have enabled all the options in Marlin. This is able to drive the second Z axis with the E1 driver, but the steps per unit is way out of whack. It seems as though it's 10x the speed of the Z axis running off the Z driver.
Where do I set the steps for this second axis? I have tried doing so by defining a second E within Marlin, but the firmware recognizes that I've defined a second extruder and tries to use the next in line that's not in use (E2). It does not seem like the firmware is honoring the steps per unit of the Z driver.
Please do not suggest that I run both z-axes from a single driver. I have been doing this (both parallel and serial) and the performance is not what I need.
Marlin has the capability of setting this and I want to take advantage of it.
I design every day. You should too.
Re: Dual Z drivers MARLIN/RAMPS (MKS Base 1.5)
September 06, 2017 01:38PM
I have not heard of wiring the second Z motor to the E-1 driver, I am sure you could but I believe the accepted way to run dual Z motors is with one driver output.
I know you don't want to, but turning up your drivers output and running dual driver as you said you tried is what I would expect is what you need....
good luck smiling smiley
Edited 1 time(s). Last edit at 09/06/2017 01:40PM by JustSumGuy.
September 06, 2017 08:26PM
set steps/mm as e1
in configuration.h find something like
* Default Axis Steps Per Unit (steps/mm)
* Override with M92
* X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]]
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 4000, 500 }
so you want to add a column and make it the same as Z value
eg #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 4000, 500, 4000 }
September 06, 2017 09:53PM
JustSumGuy
The only reason it was 'accepted' is because older firmware did not support using the 5th driver (common on RAMPS, Smoothie, Duet, etc) that is commonly reserved for a second extruder. Latest version of Marlin has all the code needed to use E1 to drive a second stepper for any axis (most commonly Z)
This is preferred over driving two motors with one stepper.
Dust
set steps/mm as e1
* Override with M92
Yeah, tried that. No effect. You and I are thinking the same, however. Ultimately I think the driver on the board I was using (MKS 1.5) did not have the proper microstepping configured for it. That's the only conclusion I could come to. Otherwise, there may be a setting/bug buried somewhere within the firmware. I brought this same topic up on the Marlin GitHub board and we seem to agree that hardware microstepping is the problem.
It's a moot point, however. I went ahead and wired to a single driver. In the past, I did this in parallel as I was concerned about low voltage. Turns out, low current is more of a concern. Steppers need to be wired in series. I must have screwed this up in the past because I could never get it to work. I must be much smarter now because I had no problem wiring things up in series and it's working great. No problems.
