Trying to make sense of the Z_STEPS_PER_MM March 25, 2011 07:16AM |
Re: Trying to make sense of the Z_STEPS_PER_MM March 25, 2011 08:04AM |
Re: Trying to make sense of the Z_STEPS_PER_MM March 25, 2011 09:26AM |
Re: Trying to make sense of the Z_STEPS_PER_MM March 25, 2011 09:50AM |
AlexRa
Well, look at the "official" picture of RP Mendel parts here...
Re: Trying to make sense of the Z_STEPS_PER_MM March 25, 2011 10:25AM |
Admin Registered: 17 years ago Posts: 7,879 |
The distance moved is the number of teeth times the belt pitch and does not depend on the diameter (assuming it is close enough that belt does not slip).Quote
If the values in configuration.h are actually accurate exterimental measurements, it might means that
whoever first measured them and put into the firmware, actually used RPed pulleys slightly smaller
than necessary (to be in sync with the belt pitch).
Re: Trying to make sense of the Z_STEPS_PER_MM March 25, 2011 10:35AM |
Re: Trying to make sense of the Z_STEPS_PER_MM March 25, 2011 02:39PM |
Re: Trying to make sense of the Z_STEPS_PER_MM March 25, 2011 07:45PM |
Re: Trying to make sense of the Z_STEPS_PER_MM March 26, 2011 06:29AM |
nophead
I store that as property of the plastic and scale the XY dimensions by that amount.
Re: Trying to make sense of the Z_STEPS_PER_MM March 26, 2011 02:48PM |
