Arduino with Gen 6 board August 22, 2011 04:40PM |
Re: Arduino with Gen 6 board August 22, 2011 05:04PM |
Re: Arduino with Gen 6 board August 23, 2011 03:59AM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: Arduino with Gen 6 board August 23, 2011 09:27AM |
............ // Now, with E codes, there is no longer any idea of turning the extruder on or off. // (But see valve on/off below.) /* //turn extruder on, forward case 101: ex[extruder_in_use]->setDirection(1); ex[extruder_in_use]->setSpeed(extruder_speed); break; //turn extruder on, reverse case 102: ex[extruder_in_use]->setDirection(0); ex[extruder_in_use]->setSpeed(extruder_speed); break; //turn extruder off */ //custom code for temperature control case 104: if (gc.seen & GCODE_S) { ex[extruder_in_use]->setTemperature((int)gc.S); } break; .............Will you please help me out here as I have just started working on this
Re: Arduino with Gen 6 board August 23, 2011 11:26AM |
Re: Arduino with Gen 6 board August 23, 2011 05:30PM |
if (e_can_step) { dda_counter.e += delta_steps.e; if (dda_counter.e > 0) { do_e_step(); real_move = true; dda_counter.e -= total_steps; if (e_direction) current_steps.e++; else current_steps.e--; } }
// Default to the origin and not going anywhere target_position.x = 0.0; target_position.y = 0.0; target_position.z = 0.0; target_position.e = 0.0; target_position.f = SLOW_XY_FEEDRATE;
