Re: Project: Teacup Firmware August 11, 2012 07:00AM |
The only issue is if the interrupt latency is so long (or the delta so short) that the new trigger time has already passed when the interrupt installs the new time- if that happens then the timer must overflow before it triggers.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware August 17, 2012 02:53PM |
Re: Project: Teacup Firmware August 17, 2012 02:57PM |
Re: Project: Teacup Firmware August 17, 2012 07:32PM |
Re: Project: Teacup Firmware August 18, 2012 05:33AM |
I'm rewriting dda for now, code is very tight and weird in some places.
Moving very slowly unfortunatly.
Re: Project: Teacup Firmware August 18, 2012 06:19AM |
Re: Project: Teacup Firmware August 21, 2012 02:13PM |
Another bad news is that code so depend on each other that one change immediatly propogate a whole bunch of required changes in other places. Which i think is very bad for any kind of project.
Re: Project: Teacup Firmware August 24, 2012 12:37PM |
Re: Project: Teacup Firmware August 25, 2012 09:49AM |
What it broken is steppers, dda, and a lot of other code
Re: Project: Teacup Firmware August 26, 2012 01:28AM |
Re: Project: Teacup Firmware August 31, 2012 05:37AM |
Re: Project: Teacup Firmware August 31, 2012 05:56PM |
Re: Project: Teacup Firmware September 26, 2012 02:56PM |
... if (((heaters_pid.p_factor == 0) && (heaters_pid.i_factor == 0) && (heaters_pid.d_factor == 0) && (heaters_pid.i_limit == 0)) || (crc_block(&heaters_pid.p_factor, 14) != eeprom_read_word((uint16_t *) &EE_factors.crc))) { heaters_pid.p_factor = DEFAULT_P; heaters_pid.i_factor = DEFAULT_I; heaters_pid.d_factor = DEFAULT_D; heaters_pid.i_limit = DEFAULT_I_LIMIT; } ...
Re: Project: Teacup Firmware September 28, 2012 06:16AM |
Also, the teensy loader seems to clear out the EEPROM, so heater.c/heater_init() reads {P,I,D,Ilim} as {0,0,0,0} with a crc of 0 that appears valid to Teacup. Maybe it would be nice to OR the two PID parameter conditions together and set the parameters to default for the zero case:
Re: Project: Teacup Firmware September 28, 2012 08:58AM |
Traumflug
(the one you gave doesn't show in which file, which line this snippet should be applied)
Re: Project: Teacup Firmware September 28, 2012 10:03AM |
--- a/crc.c +++ b/crc.c @@ -29,7 +29,7 @@ uses avr-libc's optimised crc16 routine */ uint16_t crc_block(void *data, uint16_t len) { - uint16_t crc = 0; + uint16_t crc = 0xfeed; for (; len; data++, len--) { crc = _crc16_update(crc, *((uint8_t *) data)); }
Re: Project: Teacup Firmware September 29, 2012 05:25PM |
I like 2 or 3
Maybe adding some salt to the CRC test would be a good fix?
Re: Project: Teacup Firmware September 29, 2012 05:37PM |
Re: Project: Teacup Firmware October 01, 2012 11:16AM |
diff --git a/config.teensy.h b/config.teensy.h index 7599cbd..b96cd1e 100644 --- a/config.teensy.h +++ b/config.teensy.h @@ -342,6 +342,14 @@ New plan: */ #define TEMP_RESIDENCY_TIME 60 +/** + TEMP_EWMA: Exponentially Weighted Moving Average alpha constant for smoothing noisy sensors. Undefine or set to + 1 for unfiltered data. Instrument Engineer's Handbook, 4th ed, Vol 2 p126 says values of 0.05 to 0.1 + are typical. Smaller is smoother but slower, Larger is quicker but rougher. Good hardware shouldn't + be noisy. If you need to use this, set the PID parameter to zero (M132 S0) to make the PID loop + insensitive to noise. */ +//#define TEMP_EWMA 0.1 + /// which temperature sensors are you using? List every type of sensor you use here once, to enable the appropriate code. Intercom is the gen3-style separate extruder board. // #define TEMP_MAX6675 #define TEMP_THERMISTOR diff --git a/temp.c b/temp.c index 8247a07..79a1ded 100644 --- a/temp.c +++ b/temp.c @@ -289,7 +289,15 @@ void temp_sensor_tick() { default: /* prevent compiler warning */ break; } - temp_sensors_runtime.last_read_temp = temp; + #ifndef TEMP_EWMA + temp_sensors_runtime.last_read_temp = temp; + #else /* Exponentially smooth the temperature readings */ + #define EWMA_SCALE 1024L + #define EWMA_ALPHA ((long) (TEMP_EWMA * EWMA_SCALE)) + temp_sensors_runtime.last_read_temp = (EWMA_ALPHA * temp + + (EWMA_SCALE-EWMA_ALPHA) * temp_sensors_runtime.last_read_temp + ) / EWMA_SCALE; + #endif /* TEMP_EWMA */ } if (labs((int16_t)(temp_sensors_runtime.last_read_temp - temp_sensors_runtime.target_temp)) < (TEMP_HYSTERESIS*4)) { if (temp_sensors_runtime.temp_residency < (TEMP_RESIDENCY_TIME*120))
Re: Project: Teacup Firmware October 02, 2012 03:41PM |
Re: Project: Teacup Firmware October 02, 2012 04:13PM |
config.h
temperature is "achieved" for purposes of M109 and friends when actual temperature is within [hysteresis] of target for [residency] second
Re: Project: Teacup Firmware October 03, 2012 06:58AM |
phord
I always assumed M116 was broken
phord
Should I expect M109 to work, too?
DaveX
Here's a patch that smooths temperature with an Exponentially Weighted Moving Average filter in temp.c:
Re: Project: Teacup Firmware October 03, 2012 10:57AM |
Re: Project: Teacup Firmware October 04, 2012 06:28AM |
Additionally, I think [github.com] might be needed for config_teensy.h and arduino_32U4.h to make the AIO*_ADC definitions consistent with the other chips
Re: Project: Teacup Firmware October 04, 2012 11:29AM |
Re: Project: Teacup Firmware October 05, 2012 06:36AM |
Re: Project: Teacup Firmware October 05, 2012 11:36AM |
Re: Project: Teacup Firmware October 06, 2012 06:40AM |
Re: Project: Teacup Firmware October 07, 2012 12:46AM |
for (i = 0; i < NUM_HEATERS; i++) { if (heaters.heater_pwm) { *heaters.heater_pwm = 0;
#define BANG_BANG_OFF 4to make it work.
#ifdef BANG_BANG for (i = 0; i < NUM_HEATERS; i++) { heaters.heater_pwm) = 0; } #endif
diff --git a/heater.c b/heater.c index 62d5981..b5bb83c 100644 --- a/heater.c +++ b/heater.c @@ -28,7 +28,11 @@ typedef struct { #undef DEFINE_HEATER /// \brief helper macro to fill heater definition struct from config.h // #define DEFINE_HEATER(name, port, pin, pwm) { &(port), (pin), &(pwm) }, +#ifndef BANG_BANG #define DEFINE_HEATER(name, pin) { &(pin ## _WPORT), pin ## _PIN, (pin ## _PWM) }, +#else // BANG_BANG will ignore any possible PWM pins +#define DEFINE_HEATER(name, pin) { &(pin ## _WPORT), pin ## _PIN, NULL }, +#endif static const heater_definition_t heaters[NUM_HEATERS] = { #include "config.h"
Re: Project: Teacup Firmware October 07, 2012 02:54AM |
