Re: Project: Teacup Firmware September 27, 2013 08:15PM |
vx1 = 400 mm/min, vx2 = 420 mm/min ==> continue full speed vx1 = 50 mm/min, vx2 = 600 mm/min ==> too much jerk ==> slow down
|v1 - v2| < max_jerk
x * |v1 - v2| < max_jerk
max_jerk x = ----------- |v1 - v2| if x > 1: continue full speed if x < 1: v = v_max * x
max_speed_factor = 2 << 8; for (i = 0; i < AXIS_NUM; i++) { factor = (max_jerk(i) / abs(v1(i) - v2(i))) << 8 if (factor < max_speed_factor) max_speed_factor = factor; } if (max_speed_factor >= (1 << 8)) f_corner = f_max; else f_corner = (f_max * max_speed_factor) >> 8
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware October 19, 2013 08:49AM |
git rename -m Gen7 experimental
Re: Project: Teacup Firmware October 21, 2013 06:15AM |
Re: Project: Teacup Firmware October 22, 2013 09:50AM |
git branch -m Gen7 experimental
Re: Project: Teacup Firmware October 22, 2013 10:34AM |
Re: Project: Teacup Firmware October 23, 2013 05:58AM |
Non-slow homing works, but is brutal since it accelerates into the endstops and then begins decelerating, far too late. Yikes! How is "slow" homing not the only acceptable version of homing?
Re: Project: Teacup Firmware October 24, 2013 05:59AM |
Re: Project: Teacup Firmware October 25, 2013 06:16AM |
Can i use Teacup on a atmega328 to drive a uln2003 darlington array and a unipolar stepper with normal step signals and not dir/step/enable?
Re: Project: Teacup Firmware October 28, 2013 10:16AM |
Re: Project: Teacup Firmware October 29, 2013 01:27PM |
Re: Project: Teacup Firmware November 03, 2013 02:26PM |
Re: Project: Teacup Firmware November 04, 2013 04:02AM |
I am wanting to use the z output to drive a second motor on the y axis.
Re: Project: Teacup Firmware November 06, 2013 04:13PM |
Traumflug
Likely you simply want to put both steppers onto the same stepper driver, like all the Prusa-Mendel printers do for the Z axis.
Another way to achieve this is to rewire the board and to connect both stepper driver signals to the same ATmega pin.
A software solution should be to add a z_step() to all occurrences of y_step() in dda.c. Similar for y_enable()/z_enable() if Gen6 happens to have separate enable signals for each stepper. That's not 100% accurate, but close enough.
Re: Project: Teacup Firmware November 06, 2013 06:36PM |
Re: Project: Teacup Firmware November 10, 2013 07:32AM |
Traumflug
Re: Project: Teacup Firmware November 10, 2013 11:41AM |
Re: Project: Teacup Firmware November 10, 2013 12:14PM |
Re: Project: Teacup Firmware November 11, 2013 06:40AM |
it will only go one way
Re: Project: Teacup Firmware November 11, 2013 01:47PM |
Traumflug
You have to do the same for the Dir pin. {x|y|z|e}_direction() in dda_start().
Re: Project: Teacup Firmware November 12, 2013 08:31AM |
z_direction(dda->z_direction);
Re: Project: Teacup Firmware November 20, 2013 05:44PM |
Re: Project: Teacup Firmware November 24, 2013 08:13PM |
Re: Project: Teacup Firmware November 25, 2013 03:48AM |
WARNING: file cmd/gdbserver.cpp: line 961: Invalid memory address: 0x900000
Re: Project: Teacup Firmware November 27, 2013 05:54AM |
Re: Project: Teacup Firmware November 28, 2013 08:31PM |
Re: Project: Teacup Firmware November 29, 2013 05:22AM |
How can I go about configuring the firmware to work with the above mentioned XY setup?
Re: Project: Teacup Firmware December 06, 2013 07:12PM |
Re: Project: Teacup Firmware December 12, 2013 10:43AM |
Re: Project: Teacup Firmware December 12, 2013 10:56AM |
Re: Project: Teacup Firmware December 12, 2013 12:20PM |
...Quote
zungmann
When compiling the simulation on my mac book, the compiler complain about this kind of line: TARGET startpoint __attribute__ ((__section__ (".bss")))
It says that it needs comma separated, so then I change this line and others similar to something:
zungmann
Now the simulator is working fine.
zungmann
Last one I found is that the simulator seems to work with config.default.h config. When I used config for gen7 1.4, I just get flat line. I have not seen further … so not sure which one to change.
