Re: Project: FiveD on Arduino February 11, 2011 03:29PM |
Re: Project: FiveD on Arduino February 12, 2011 08:07AM |
$ make make: *** Keine Regel vorhanden, um das Target »config.h.dist«, benötigt von »config.h«, zu erstellen. Schluss.
Re: Project: FiveD on Arduino February 12, 2011 08:08AM |
Re: Project: FiveD on Arduino February 12, 2011 08:12AM |
Re: Project: FiveD on Arduino February 12, 2011 08:38AM |
avr-objdump -s -j .fuse mendel.o | perl -ne '/\s0000\s([0-9a-f]{2})/ && print "$$1\n"' > lfuse avr-objdump -s -j .fuse mendel.o | perl -ne '/\s0000\s..([0-9a-f]{2})/ && print "$$1\n"' > hfuse avr-objdump -s -j .fuse mendel.o | perl -ne '/\s0000\s....([0-9a-f]{2})/ && print "$$1\n"' > efuseAll these 3 files are EMPTY after running this commands! I don't think this wanted.
Re: Project: FiveD on Arduino February 12, 2011 10:10AM |
Re: Project: FiveD on Arduino February 12, 2011 12:33PM |
In English: No roule found to create the target "config.h.dist" which is needed by "config.h".
Any idea what this mean?
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: FiveD on Arduino February 12, 2011 04:53PM |
Re: Project: FiveD on Arduino February 13, 2011 02:14AM |
Re: Project: FiveD on Arduino February 13, 2011 02:50AM |
Re: Project: FiveD on Arduino February 13, 2011 12:37PM |
Re: Project: FiveD on Arduino February 13, 2011 01:46PM |
avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.03s avrdude: Device signature = 0x000000 avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check. avrdude done. Thank you. make: *** [program] Fehler 1
Re: Project: FiveD on Arduino February 13, 2011 02:16PM |
* If your heater isn't on a PWM-able pin, set heater_pwm to zero and we'll *
* use bang-bang output. Note that PID will still be used *
DEFINE_HEATER(extruder, PORTA, PINA0, 0)
config.h:291: Fehler: Als Operand für unäres »&« wird L-Wert erfordert
Re: Project: FiveD on Arduino February 13, 2011 03:00PM |
Re: Project: FiveD on Arduino February 13, 2011 03:14PM |
Re: Project: FiveD on Arduino February 13, 2011 03:50PM |
Re: Project: FiveD on Arduino February 13, 2011 03:55PM |
Re: Project: FiveD on Arduino February 13, 2011 06:03PM |
Re: Project: FiveD on Arduino February 13, 2011 06:47PM |
Re: Project: FiveD on Arduino February 13, 2011 07:37PM |
Re: Project: FiveD on Arduino February 14, 2011 08:47PM |
Re: Project: FiveD on Arduino February 14, 2011 11:54PM |
Re: Project: FiveD on Arduino February 15, 2011 08:29AM |
Re: Project: FiveD on Arduino February 15, 2011 02:22PM |
Re: Project: FiveD on Arduino February 15, 2011 04:43PM |
Re: Project: FiveD on Arduino February 15, 2011 06:42PM |
Re: Project: FiveD on Arduino February 15, 2011 07:22PM |
Increasing PWM output February 15, 2011 07:36PM |
Admin Registered: 17 years ago Posts: 179 |
Re: Project: FiveD on Arduino February 15, 2011 08:44PM |
Re: Project: FiveD on Arduino February 15, 2011 09:10PM |
