Re: Project: Teacup Firmware April 03, 2011 09:53PM |
Re: Project: Teacup Firmware April 03, 2011 10:00PM |
Re: Project: Teacup Firmware April 03, 2011 10:07PM |
The SY35ST36-1004B is 1.8 degrees-per-step has a double shaft and a holding torque of 14Ncm.
Re: Project: Teacup Firmware April 03, 2011 10:14PM |
Re: Project: Teacup Firmware April 04, 2011 05:20AM |
So @16microsteps we get 3200 steps per revolution.
So on the basis of these figures and the resolutions that result 30K would appear to be a bit slow and the resolution is arguably sub micron and excessive.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware April 04, 2011 07:29PM |
Re: Project: Teacup Firmware April 04, 2011 08:38PM |
sliptonic
Re: Project: Teacup Firmware April 05, 2011 10:14AM |
Re: Project: Teacup Firmware April 05, 2011 05:34PM |
Re: Project: Teacup Firmware April 05, 2011 06:02PM |
git push origin masteris all you should need to push to upstream master.
git push origin branchnamehereis all it takes
sliptonic
Re: Project: Teacup Firmware April 05, 2011 06:29PM |
Re: Project: Teacup Firmware April 05, 2011 06:55PM |
Re: Project: Teacup Firmware April 05, 2011 06:57PM |
Re: Project: Teacup Firmware April 05, 2011 07:21PM |
Re: Project: Teacup Firmware April 05, 2011 09:38PM |
Re: Project: Teacup Firmware April 05, 2011 10:57PM |
Re: Project: Teacup Firmware April 06, 2011 10:57AM |
Re: Project: Teacup Firmware April 06, 2011 12:01PM |
Re: Project: Teacup Firmware April 06, 2011 02:02PM |
Re: Project: Teacup Firmware April 06, 2011 02:06PM |
Re: Project: Teacup Firmware April 06, 2011 02:34PM |
Re: Project: Teacup Firmware April 06, 2011 05:47PM |
Re: Project: Teacup Firmware April 06, 2011 06:15PM |
Re: Project: Teacup Firmware April 06, 2011 06:27PM |
Re: Project: Teacup Firmware April 06, 2011 06:29PM |
Re: Project: Teacup Firmware April 06, 2011 06:52PM |
g0 z10 ok Q3/3 m114 ok X:1000,Y:1000,Z:8330,E:0,F:6000 g92 z0 ok Q3/3E m114 ok X:1000,Y:1000,Z:0,E:0,F:6000 g92 e0 ok Q3/3E m114 ok X:0,Y:0,Z:0,E:0,F:6000
Re: Project: Teacup Firmware April 06, 2011 07:51PM |
Re: Project: Teacup Firmware April 06, 2011 08:13PM |
Re: Project: Teacup Firmware April 06, 2011 08:51PM |
As you can see, a G92 on Z axis is only setting the Z but a G92 only on the E is resetting X,Y,and Z as well.
Re: Project: Teacup Firmware April 06, 2011 09:42PM |
