Teacup Bug or wrong Setting April 16, 2017 03:35PM |
/***************************************************************************\ * * * 6. MECHANICAL/HARDWARE * * * \***************************************************************************/ /** \def KINEMATICS_STRAIGHT KINEMATICS_COREXY This defines the type of kinematics your printer uses. That's essential! Valid values (see dda_kinematics.h): KINEMATICS_STRAIGHT Motors move axis directions directly. This is the traditional type, found in many printers, including Mendel, Prusa i3, Mendel90, Ormerod, Mantis. KINEMATICS_COREXY A bot using CoreXY kinematics. Typical for CoreXY are long and crossing toothed belts and a print head moving on the X-Y-plane. */ #define KINEMATICS_STRAIGHT //#define KINEMATICS_COREXY /** \def STEPS_PER_M_X STEPS_PER_M_Y STEPS_PER_M_Z STEPS_PER_M_E Steps per meter ( = steps per mm * 1000 ), calculate these values appropriate for your machine. All numbers are integers, so no decimal point, please :-) Valid range: 20 to 4'0960'000 (0.02 to 40960 steps/mm) */ #define STEPS_PER_M_X 533333 #define STEPS_PER_M_Y 533333 #define STEPS_PER_M_Z 533333 #define STEPS_PER_M_E 48000 /** \def MAXIMUM_FEEDRATE_X MAXIMUM_FEEDRATE_Y MAXIMUM_FEEDRATE_Z MAXIMUM_FEEDRATE_E Used for G0 rapid moves and as a cap for all other feedrates. */ #define MAXIMUM_FEEDRATE_X 900 #define MAXIMUM_FEEDRATE_Y 900 #define MAXIMUM_FEEDRATE_Z 900 #define MAXIMUM_FEEDRATE_E 900 /** \def SEARCH_FEEDRATE_X SEARCH_FEEDRATE_Y SEARCH_FEEDRATE_Z Used when doing precision endstop search and as default feedrate. No SEARCH_FEEDRATE_E, as E can't be searched. */ #define SEARCH_FEEDRATE_X 200 #define SEARCH_FEEDRATE_Y 200 #define SEARCH_FEEDRATE_Z 50 /** \def ENDSTOP_CLEARANCE_X ENDSTOP_CLEARANCE_Y ENDSTOP_CLEARANCE_Z When hitting an endstop, Teacup properly decelerates instead of doing an aprupt stop to save your mechanics. Ineviteably, this means it overshoots the endstop trigger point by some distance. To deal with this, Teacup adapts homing movement speeds to what your endstops can deal with. The higher the allowed acceleration ( = deceleration, see #define ACCELERATION) and the more clearance the endstop comes with, the faster Teacup will do homing movements. Set here how many micrometers (mm * 1000) your endstop allows the carriage to overshoot the trigger point. Typically 1000 or 2000 for mechanical endstops, more for optical ones. You can set it to zero, in which case SEARCH_FEEDRATE_{XYZ} is used, but expect very slow homing movements. Units: micrometers Sane values: 0 to 20000 (0 to 20 mm) Valid range: 0 to 1000000 */ #define ENDSTOP_CLEARANCE_X 20 #define ENDSTOP_CLEARANCE_Y 20 #define ENDSTOP_CLEARANCE_Z 20 /** \def X_MIN X_MAX Y_MIN Y_MAX Z_MIN Z_MAX Soft axis limits. Define them to your machine's size relative to what your G-code considers to be the origin (typically the bed's center or the bed's front left corner). Note that relocating the origin at runtime with G92 will also relocate these limits. Not defining them at all will disable limits checking and make the binary about 250 bytes smaller. Enabling only some of them is perfectly fine. Units: millimeters Sane values: according to printer build room size Valid range: -1000.0 to 1000.0 */ #define X_MIN -100 #define X_MAX 200 #define Y_MIN -80 #define Y_MAX 200 #define Z_MIN 0 #define Z_MAX 59.7 /** \def E_ABSOLUTE Some G-code creators produce relative length commands for the extruder, others absolute ones. G-code using absolute lengths can be recognized when there are G92 E0 commands from time to time. If you have G92 E0 in your G-code, define this flag. This is the startup default and can be changed with M82/M83 while running. */ #define E_ABSOLUTE /** \def ACCELERATION_REPRAP ACCELERATION_RAMPING ACCELERATION_TEMPORAL Choose optionally one of ACCELERATION_REPRAP, ACCELERATION_RAMPING or ACCELERATION_TEMPORAL. With none of them defined, movements are done without acceleration. Recommended is ACCELERATION_RAMPING. */ //#define ACCELERATION_REPRAP #define ACCELERATION_RAMPING //#define ACCELERATION_TEMPORAL /** \def ACCELERATION How fast to accelerate when using ACCELERATION_RAMPING. Start with 10 for milling (high precision) or 1000 for printing. Units: mm/s^2 Useful range: 1 to 10'000 */ #define ACCELERATION 1000 /** \def LOOKAHEAD Define this to enable look-ahead during *ramping* acceleration to smoothly transition between moves instead of performing a dead stop every move. Enabling look-ahead requires about 3600 bytes of flash memory. */ #define LOOKAHEAD /** \def MAX_JERK_X MAX_JERK_Y MAX_JERK_Z MAX_JERK_E When performing look-ahead, we need to decide what an acceptable jerk to the mechanics is. Look-ahead attempts to instantly change direction at movement crossings, which means instant changes in the speed of the axes participating in the movement. Define here how big the speed bumps on each of the axes is allowed to be. If you want a full stop before and after moving a specific axis, define MAX_JERK of this axis to 0. This is often wanted for the Z axis. If you want to ignore jerk on an axis, define it to twice the maximum feedrate of this axis. Having these values too low results in more than neccessary slowdown at movement crossings, but is otherwise harmless. Too high values can result in stepper motors suddenly stalling. If angles between movements in your G-code are small and your printer runs through entire curves full speed, there's no point in raising the values. Units: mm/min Sane values: 0 to 400 Valid range: 0 to 65535 */ #define MAX_JERK_X 200 #define MAX_JERK_Y 200 #define MAX_JERK_Z 0 #define MAX_JERK_E 200 /***************************************************************************\ * * * 7. MISCELLANEOUS OPTIONS * * * \***************************************************************************/ /** \def USE_INTERNAL_PULLUPS Most controller chips feature internal pullup resistors on their input pins, which get used for endstops by turning on this switch. Don't turn it on when using endstops which need no pull resistor, e.g. optical endstops, because pull resistors are counterproductive there. One can't use USE_INTERNAL_PULLUPS and USE_INTERNAL_PULLDOWNS at the same time, of course. */ //#define USE_INTERNAL_PULLUPS /** \def USE_INTERNAL_PULLDOWNS Some controller chips feature internal pulldown resistors on their input pins, which get used for endstops by turning on this switch. Don't turn it on when using endstops which need no pull resistor, e.g. optical endstops, because pull resistors are counterproductive there. One can't use USE_INTERNAL_PULLDOWNS and USE_INTERNAL_PULLUPS at the same time, of course. */ //#define USE_INTERNAL_PULLDOWNS /** \def Z_AUTODISABLE Automatically disable Z axis when not in use. This is useful for printers with a self-locking Z axis, e.g. the various Mendel derivates. Other printers have a heavy Z axis or a not self-locking spindle. In that case you should not activate this. This option has no effect on controllers with a common stepper enable pin. */ #define Z_AUTODISABLE /** \def TEMP_HYSTERESIS Actual temperature must be target +/- this hysteresis before target temperature is considered to be achieved. Also, BANG_BANG tries to stay within half of this hysteresis. Unit: degree Celsius */ #define TEMP_HYSTERESIS 10 /** \def TEMP_RESIDENCY_TIME Actual temperature must be close to target (within set temperature +- TEMP_HYSTERESIS) for this long before target is achieved (and a M116 succeeds). Unit: seconds */ #define TEMP_RESIDENCY_TIME 60 /** \def TEMP_EWMA Smooth noisy temperature sensors. Good hardware shouldn't be noisy. Set to 1000 for unfiltered data (and a 140 bytes smaller binary). Instrument Engineer's Handbook, 4th ed, Vol 2 p126 says values of 50 to 100 are typical. Smaller is smoother but slower adjusting, larger is quicker but rougher. If you need to use this, set the PID parameter to zero (M132 S0) to make the PID loop insensitive to noise. Valid range: 1 to 1000 */ #define TEMP_EWMA 100 /** \def REPORT_TARGET_TEMPS With this enabled, M105 commands will return the current temperatures along with the target temps, separated by a slash: ok T:xxx.x/xxx.x B:xxx.x/xxx.x With this disabled, only temps will be returned: ok T:xxx.x B:xxx.x Enabling adds 78 bytes to the image. */ #define REPORT_TARGET_TEMPS /** \def HEATER_SANITY_CHECK Check if heater responds to changes in target temperature, disable and spit errors if not largely untested, please comment in forum if this works, or doesn't work for you! */ //#define HEATER_SANITY_CHECK /** \def EECONFIG Enable EEPROM configuration storage. Enabled by default. Commenting this out makes the binary several hundred bytes smaller, so you might want to disable EEPROM storage on small MCUs, like the ATmega168. */ //#define EECONFIG /** \def BANG_BANG Drops PID loop from heater control, reduces code size significantly (1300 bytes!). */ //#define BANG_BANG /** \def BANG_BANG_ON PWM value for Bang Bang 'on'. */ //#define BANG_BANG_ON 200 /** \def BANG_BANG_OFF PWM value for Bang Bang 'off'. */ //#define BANG_BANG_OFF 45 /** \def MOVEBUFFER_SIZE Move buffer size, in number of moves. Note that each move takes a fair chunk of ram (107 bytes as of this writing), so don't make the buffer too big. However, a larger movebuffer will probably help with lots of short consecutive moves, as each move takes a bunch of math (hence time) to set up so a longer buffer allows more of the math to be done during preceding longer moves. */ #define MOVEBUFFER_SIZE 8 /** \def DC_EXTRUDER DC_EXTRUDER_PWM If you have a DC motor extruder, configure it as a "heater" above and define this value as the index or name. You probably also want to comment out E_STEP_PIN and E_DIR_PIN in the Pinouts section above. */ //#define DC_EXTRUDER HEATER_motor //#define DC_EXTRUDER_PWM 180 /** \def USE_WATCHDOG Teacup implements a watchdog, which has to be reset every 250ms or it will reboot the controller. As rebooting (and letting the GCode sending application trying to continue the build with a then different Home point) is probably even worse than just hanging, and there is no better restore code in place, this is disabled for now. */ //#define USE_WATCHDOG /** \def TH_COUNT Temperature history count. This is how many temperature readings to keep in order to calculate derivative in PID loop higher values make PID derivative term more stable at the expense of reaction time. */ #define TH_COUNT 8 /** \def FAST_PWM Teacup offers two PWM frequencies, 76(61) Hz and 78000(62500) Hz on a 20(16) MHz electronics. The slower one is the default, as it's the safer choice and reduces MOSFET heating. Drawback is, in a quiet environment you might notice the heaters and your power supply humming. Uncomment this option if you want to get rid of this humming and can afford a hotter MOSFET or want faster PWM for other reasons. See also: [reprap.org] */ //#define FAST_PWM /** \def PID_SCALE This is the scaling of internally stored PID values. 1024L is a good value. */ #define PID_SCALE 1024L /** \def ENDSTOP_STEPS Number of steps to run into the endstops intentionally. As endstops trigger false alarm sometimes, Teacup debounces them by counting a number of consecutive positives. Use 4 or less for reliable endstops, 8 or even more for flaky ones. Valid range: 1...255. */ #define ENDSTOP_STEPS 4 /** \def CANNED_CYCLE G-code commands in this string will be executed over and over again, without user interaction or even a serial connection. It's purpose is e.g. for exhibitions or when using Teacup for other purposes than printing. You can add any G-code supported by Teacup. Note: don't miss these newlines (\n) and backslashes (\). */ /* #define CANNED_CYCLE "G1 X100 F3000\n" \ "G4 P500\n" \ "G1 X0\n" \ "G4 P500\n" */
Re: Teacup Bug or wrong Setting April 17, 2017 05:28PM |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Teacup Bug or wrong Setting May 22, 2017 02:07PM |
Re: Teacup Bug or wrong Setting May 28, 2017 11:39AM |
Re: Teacup Bug or wrong Setting May 30, 2017 05:48AM |
Re: Teacup Bug or wrong Setting May 30, 2017 12:18PM |
Re: Teacup Bug or wrong Setting May 31, 2017 11:04AM |
Re: Teacup Bug or wrong Setting June 01, 2017 03:26AM |
Dj EKI
I drive first "Z" home. "Z" is open. Then I drive "Y" home. Then I try to send M119, but there is no answer. I disconnect the connection and restore it. Then I send M119 and get this message:
X_min: open y_min: triggered z_max: open.
On my video is to see how it reaches "Y" end stops and stops. Unfortunately, it does not react anymore and only buzzes loudly. If the end stops were not, the carriage would leave the rails.
Re: Teacup Bug or wrong Setting June 01, 2017 06:55PM |
Admin Registered: 13 years ago Posts: 7,005 |
