No X axis movement?
Posted by hellorous
No X axis movement?
September 14, 2013 11:05AM
Hello I have a orignal mendel with gen3 reprap v1.2 . I have movement from Y and Z but not X, if I plug Y or Z into X it moves fine. The opto end sensors work for Z and Y ,but atm I'm not getting the X one to light up. I even swapped opto ends to see if was the problem but it is not. So question I have is what would make the X port from main board not move the X axis? Not having opto end sensor working?Bad main board? or did I forget something else? So close but yet so far smiling smiley Ty in advance.
Re: No X axis movement?
September 14, 2013 11:26AM
Figured it out was weird i swapped the cable from Y with X and now X and Y both work...along with Z. Weird...
September 15, 2013 12:27AM
You probably have an intermittent connection on one of the ends of that cable. If the connectors use crimped on pins, they may need to be redone. I solder all the pins on my cable ends to make sure they're reliable.
September 15, 2013 09:39AM
Ty I'll check into what you said.
