Missing material on last layer June 30, 2013 11:56AM |
Re: Missing material on last layer July 04, 2013 12:47PM |
Re: Missing material on last layer July 04, 2013 01:19PM |
Re: Missing material on last layer July 05, 2013 11:31AM |
Re: Missing material on last layer July 05, 2013 11:41AM |
Re: Missing material on last layer July 05, 2013 11:49AM |
Re: Missing material on last layer July 05, 2013 12:58PM |
Re: Missing material on last layer July 05, 2013 03:02PM |
Re: Missing material on last layer July 05, 2013 03:22PM |
Re: Missing material on last layer July 05, 2013 04:52PM |
If you have an M84 "stop all motors" command in your end code then that can cause whatever is in your command buffer to stop executing. That is, G commands are buffered, M commands are executed immediately. So if there are any remaining G commands in the buffer (which I believe is only 16 commands long) when the M84 comes along, then you'll lose them. Placing an M400 "wait for buffer to clear" before your M84 will fix that problem.
Re: Missing material on last layer July 05, 2013 08:14PM |
