Problem with Z height when printing. July 05, 2013 07:31PM |
; generated by Slic3r 0.9.10b on 2013-07-05 at 23:16:44 ; layer_height = 0.4 ; perimeters = 3 ; top_solid_layers = 3 ; bottom_solid_layers = 3 ; fill_density = 0.4 ; perimeter_speed = 30 ; infill_speed = 60 ; travel_speed = 130 ; nozzle_diameter = 0.5 ; filament_diameter = 3 ; extrusion_multiplier = 1 ; perimeters extrusion width = 0.53mm ; infill extrusion width = 0.53mm ; solid infill extrusion width = 0.53mm ; top infill extrusion width = 0.53mm ; first layer extrusion width = 0.80mm
// default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {80.2691,80.8389,3973.6676,695.6} // default steps per unit for ultimaker #define DEFAULT_MAX_FEEDRATE {500, 500, 5, 25} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for r retracts // The speed change that does not require acceleration (i.e. the software might assume it can be done instanteneously) #define DEFAULT_XYJERK 20.0 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
Re: Problem with Z height when printing. July 06, 2013 12:12AM |
Re: Problem with Z height when printing. July 06, 2013 04:33AM |
Re: Problem with Z height when printing. July 06, 2013 04:38AM |
Re: Problem with Z height when printing. July 06, 2013 05:33AM |
Re: Problem with Z height when printing. July 06, 2013 05:46AM |
Re: Problem with Z height when printing. July 06, 2013 05:55PM |
Re: Problem with Z height when printing. July 06, 2013 07:40PM |
Re: Problem with Z height when printing. July 07, 2013 07:37AM |
Re: Problem with Z height when printing. July 07, 2013 07:46AM |
Re: Problem with Z height when printing. July 07, 2013 09:47AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Problem with Z height when printing. July 07, 2013 07:22PM |
Re: Problem with Z height when printing. July 07, 2013 08:27PM |
Re: Problem with Z height when printing. July 07, 2013 09:43PM |
Re: Problem with Z height when printing. July 10, 2013 06:11AM |
Re: Problem with Z height when printing. July 10, 2013 12:58PM |
Re: Problem with Z height when printing. July 12, 2013 05:57AM |
