Hey guys.
I have bought and build a Reprap pro mendel, from reprappro.com.
I have printed different print with different result and has tweaked and calibrated here and there.
I am now trying to print a bigger print and the last two try the extruder has starting clicking and just moving back and forth. It happen both time, after approx 5 - 6 hours of print time .
I have tried to clean out the nozzle and PTFE tube without luck.
I have measured the voltage at the pot-meter at the stepper controller and have raised it from 0.6 to 0.7 V. Without luck.
I have put a fan to cool down the step controller and have put a heatsink on the extruder motor. Without luck.
Today I tried to start the printer again, but during the first layer the stepper start clicking again.
See video: [
youtu.be]
Anybody got any idea, what to do?
Additional info from firmware.
echo:Marlin 1.0.1 RRP
echo: Last Updated: 2013-03-26-RJ | Author: RepRapPro
echo: Free Memory: 11517 PlannerBufferBytes: 1232
echo:Using Default settings:
echo
teps per unit:
echo: M92 X92.635 Y92.635 Z4000.000 E660.000
echo:Maximum feedrates (mm/s):
echo: M203 X300.000 Y300.000 Z3.000 E45.000
echo:Maximum Acceleration (mm/s2):
echo: M201 X800 Y800 Z30 E800
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S1000.000 T1000.000
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s), K=advance_k
echo: M205 S0.000 T0.000 B20000 X15.000 Z0.400 E15.000
echo: M206 X0.000 Y0.000 Z0.000
echo: M208 X210.000 Y210.000 Z140.000
echo
ID settings:
echo: M301 P12.000 I2.200 D80.000 W125
echo:Thermistor settings: M304 Hh Bb Rr Tt, H0=Bed, H1..n=nozzle, b=thermistor beta value, r=series resistor, t=thermistor resistance as 25C
echo: M304 H0
B3480 R4700 T10000 M304 H1
B3960 R4700 T100000
FPU Enabled no
transform correction not enabledecho
D card ok
Here is a download link for the last version of the G-Code i was trying to print:
dl.dropboxusercontent.com]
Thanks in advance.
