Re: Bed Auto Leveling.. check this out October 22, 2013 05:25AM |
Re: Bed Auto Leveling.. check this out October 22, 2013 06:58AM |
Re: Bed Auto Leveling.. check this out October 22, 2013 08:18AM |
Re: Bed Auto Leveling.. check this out October 22, 2013 08:22AM |
Re: Bed Auto Leveling.. check this out October 23, 2013 05:13PM |
Re: Bed Auto Leveling.. check this out October 23, 2013 05:42PM |
For RAMPS users: By default, RAMPS have no power on servo bus (if you happen to have a multimeter, check the voltage on servo power pins). In order to get the servo working, you need to supply 5V to 5V pin.. You can do it using your power supply (if it has a 5V output) or jumping the "Vcc" from Arduino to the 5V RAMPS rail. These 2 pins are located just between the Reset Button and the yellow fuses... There are marks in the board showing 5V and VCC.. just connect them.. If jumping the arduino Vcc do RAMPS 5V rail, take care to not use a power hungry servo, otherwise you will cause a blackout in the arduino board ;-)
Re: Bed Auto Leveling.. check this out October 23, 2013 09:17PM |
Re: Bed Auto Leveling.. check this out October 25, 2013 03:13AM |
Re: Bed Auto Leveling.. check this out October 25, 2013 03:25AM |
Re: Bed Auto Leveling.. check this out October 25, 2013 04:19PM |
Re: Bed Auto Leveling.. check this out October 26, 2013 06:32PM |
Re: Bed Auto Leveling.. check this out October 26, 2013 07:05PM |
Re: Bed Auto Leveling.. check this out October 27, 2013 08:52AM |
Re: Bed Auto Leveling.. check this out October 27, 2013 08:57AM |
Re: Bed Auto Leveling.. check this out October 27, 2013 09:09AM |
Re: Bed Auto Leveling.. check this out October 27, 2013 05:30PM |
Re: Bed Auto Leveling.. check this out October 27, 2013 05:46PM |
Re: Bed Auto Leveling.. check this out October 27, 2013 05:54PM |
Re: Bed Auto Leveling.. check this out October 27, 2013 06:08PM |
Re: Bed Auto Leveling.. check this out October 27, 2013 07:59PM |
Re: Bed Auto Leveling.. check this out October 27, 2013 08:38PM |
Re: Bed Auto Leveling.. check this out October 28, 2013 03:13AM |
Re: Bed Auto Leveling.. check this out October 28, 2013 12:18PM |
Re: Bed Auto Leveling.. check this out October 28, 2013 03:16PM |
Re: Bed Auto Leveling.. check this out October 28, 2013 08:42PM |
Re: Bed Auto Leveling.. check this out October 30, 2013 03:47AM |
Re: Bed Auto Leveling.. check this out October 30, 2013 04:17AM |
Re: Bed Auto Leveling.. check this out October 30, 2013 04:22AM |
Re: Bed Auto Leveling.. check this out October 30, 2013 04:38AM |
Re: Bed Auto Leveling.. check this out October 30, 2013 04:46AM |
