Re: Bed Auto Leveling.. check this out February 15, 2015 02:22PM |
Re: Bed Auto Leveling.. check this out February 15, 2015 02:25PM |
Re: Bed Auto Leveling.. check this out February 15, 2015 02:39PM |
Re: Bed Auto Leveling.. check this out February 15, 2015 02:44PM |
Re: Bed Auto Leveling.. check this out February 15, 2015 03:04PM |
Re: Bed Auto Leveling.. check this out February 15, 2015 03:06PM |
Re: Bed Auto Leveling.. check this out February 15, 2015 03:21PM |
Re: Bed Auto Leveling.. check this out February 15, 2015 03:22PM |
Re: Bed Auto Leveling.. check this out February 15, 2015 03:28PM |
Re: Bed Auto Leveling.. check this out February 15, 2015 03:33PM |
Re: Bed Auto Leveling.. check this out February 15, 2015 04:16PM |
Re: Bed Auto Leveling.. check this out February 15, 2015 04:18PM |
Re: Bed Auto Leveling.. check this out February 15, 2015 06:29PM |
Re: Bed Auto Leveling.. check this out February 16, 2015 01:17AM |
Re: Bed Auto Leveling.. check this out February 18, 2015 03:43AM |
Re: Bed Auto Leveling.. check this out February 20, 2015 04:34AM |
Re: Bed Auto Leveling.. check this out February 20, 2015 04:56AM |
Re: Bed Auto Leveling.. check this out March 15, 2015 06:56PM |
Re: Bed Auto Leveling.. check this out March 15, 2015 09:15PM |
Re: Bed Auto Leveling.. check this out March 15, 2015 10:03PM |
stephenrc
Remove the space you have between the - and the number on line 430 in Configuration.h and try again.
Re: Bed Auto Leveling.. check this out March 16, 2015 08:59AM |
enzo1027
stephenrc
No dice. :/
Still the same compile error. I downloaded Marlin (newest stable version) yesterday, and only changed my what I needed to make my Folger-Tech Prusa work (ie. inverting endstops, change some travel speeds, etc). I then went in and enabled auto bed leveling with the OEM Marlin numbers. I was able to move my probe, retract the servo, locate my proper offset, etc. It would even complete the bed leveling sequence with the OEM numbers. As soon as I enter mine in, it won't compile. I don't get it.
As an FYI, looking at my Prusa, the x endstop and motor are on the right, my y endstop is closest to you on the right, and z is on the probe. I believe this may be the opposite origin as some Prusas; I've noticed a lot of them with the x axis motor on the left, and a lot have their y endstop in the back right corner. If there is any other information anyone needs, please let me know. Again, I really appreciate anyone's help.
Re: Bed Auto Leveling.. check this out March 16, 2015 12:15PM |
tjb1
enzo1027
stephenrc
No dice. :/
Did you read the commented line above the area you are changing numbers??
"// X and Y offsets must be integers"
You entered a floating number in an area that only accepts integers, this is what the error messages are telling you.
Re: Bed Auto Leveling.. check this out March 26, 2015 03:09PM |
Re: Bed Auto Leveling.. check this out April 06, 2015 07:24AM |
Re: Bed Auto Leveling.. check this out April 06, 2015 07:57AM |
Re: Bed Auto Leveling.. check this out April 06, 2015 08:31AM |
Re: Bed Auto Leveling.. check this out April 06, 2015 01:22PM |
Re: Bed Auto Leveling.. check this out April 07, 2015 02:37AM |
johnka
When I run G28 it moves to X,Y home position (0,0), then it moves to the middle of the bed, extends the probe and lowing down until it hits the microswitch. It hits the switch 3,55mm below my nozzle. I have entered the offset values on configuration. If I start a print the nozzle doesn't touch the bed. It stays at Z offset (3,55mm) where the switch triggered.
What am I missing?
See my configuration file.
Re: Bed Auto Leveling.. check this out April 07, 2015 06:19PM |
Re: Bed Auto Leveling.. check this out April 08, 2015 02:41AM |
johnka
@touchthebitum I have uncomment both.
@Brainscan I set it to false when I wanted to find the offsets for X,Y,Z. After that procedure I set it to true and reflashed the firmware.
When I home Z it declares as Z=0 the point it hit the probe microswitch but the nozzle is a few mm higher. With G1 Z0 the nozzle doesn't touch the glass. It stays at Z_PROBE_OFFSET_FROM_EXTRUDER height. I am still able to move the nozzle lower manually with pronterface as many mm as the Z probe offset is.
I ran the M851 to adjust the Z probe offset. I think this is the step I was missing. Now with G1 Z0 the nozzle touches the glass. The only problem is that I am still able to move my nozzle manually below Z=0 as many mm as Z_PROBE_OFFSET_FROM_EXTRUDER is, and it may damage the glass or the nozzle itself. Is there any fix? Am I still missing anything?
Thank you
