Problem with top layer November 26, 2013 02:51AM |
Re: Problem with top layer November 26, 2013 01:36PM |
Re: Problem with top layer November 27, 2013 04:04AM |
Re: Problem with top layer November 27, 2013 04:10AM |
Re: Problem with top layer November 27, 2013 08:28AM |
Re: Problem with top layer November 27, 2013 09:58AM |
JNZ
Because your "Nozle dia = 0.35mm", you have to change "Botom solid layers = 2 Top solid layers = 3", you should add a point in front of digit, should be 0.2 and 0.3.
Just try it, good luck
Re: Problem with top layer November 27, 2013 10:02AM |
uncle_bob
Which of the "latest versions" of Slic3r are you using. They have 0.9.10b out as released code and 1.0.0rc1 as more or less beta. At least on my printer, 0.9.10b had top layer issues that were fixed in 1.0.0rc1
Re: Problem with top layer November 27, 2013 11:02AM |
Re: Problem with top layer November 27, 2013 09:22PM |
tadejv
JNZ
Hi, are you shure this will work?
As far I know the top/botom layer nuber is the nuber of layers.
So in my case i do bottom 2 layers each 0.1mm high, and on top I do 3 layers each 0.1mm
Re: Problem with top layer November 27, 2013 10:04PM |
Re: Problem with top layer November 28, 2013 02:00AM |
uncle_bob
When I set a 4 or a in Slic3r for top and bottom layers with a 0.3mm layer height, it prints 4 layers of 0.3 mm. It does not print twelve layers. It may do something completely different when it sees a 0.x number in that field.
Re: Problem with top layer December 04, 2013 06:11AM |
Re: Problem with top layer December 04, 2013 01:22PM |
Re: Problem with top layer December 05, 2013 11:59AM |
Re: Problem with top layer December 05, 2013 01:21PM |
Re: Problem with top layer December 05, 2013 02:29PM |
uncel_bob
Unless you have a nozzle diameter below 0.2 mm, a 0.1 mm layer height simply isn't going to work for extrusion. It would only work with that nozzle if your bed is level to about 0.01 mm (and thus flat to better than 0.01 mm). Even with auto bed leveling and a fancy bed those numbers will be very hard to hit.
Re: Problem with top layer December 05, 2013 07:12PM |
