Prusa I3 from Maker Farm December 13, 2013 03:23AM |
Re: Prusa I3 from Maker Farm December 13, 2013 04:03PM |
Re: Prusa I3 from Maker Farm December 13, 2013 10:43PM |
Re: Prusa I3 from Maker Farm December 14, 2013 09:11AM |
Re: Prusa I3 from Maker Farm December 15, 2013 10:20PM |
Re: Prusa I3 from Maker Farm December 16, 2013 07:33PM |
Re: Prusa I3 from Maker Farm December 17, 2013 12:22PM |
uncle_bob
I've tried Slic3r, Cura and Kiss. They all have a similar issue with thin features.
Re: Prusa I3 from Maker Farm December 17, 2013 05:40PM |
Re: Prusa I3 from Maker Farm December 17, 2013 08:50PM |
Re: Prusa I3 from Maker Farm December 17, 2013 10:35PM |
uncle_bob
The printer is probably doing fine. It's a design for manufacture issue.
The printer can only lay down fixed width strips of plastic. That's all the software / firmware / hardware knows about. If you have a 0.4 mm nozzle, you can set it up for something in the 0.4 to 0.5 mm width range. Let's say it's 0.4 mm.
If you ask the printer to do a wall that's 0.4 mm wide it lays down one strip. If you ask for 0.8 mm wide it lays down two. If you ask for 1.2 mm it lays down three. Everything works fine / looks fine.
If you ask for a wall that's 0.5 mm, it can't do it. I puts down a 0.4 mm wall. If you ask for a 1.0 mm wall, it puts down two 0.4 mm tracks and a 0.2 mm gap. If you ask for a 1.5 mm wall it will put down 3 tracks and only fill 1.2 mm.
The wall thickness on the part needs to be designed to match the printer. That's something you do with a CAD program before you generate the stl file that feeds into Slic3r. If you only have one wall, and you know exactly what it is, you might be able to manipulate your layer height and extrusion width to fill things better. That's generally not an easy thing to do.
Edvardas
Just go to different slicer... Cura or Kisslicer. Kisslicer does a great job on making lines overlap.
Antslake
You should also go to the calibration wiki, and look for the fine tuning of the esteps.
Another possibility is to increase flow a bit.
Another possibility is that your filament is not exactly 3mm, you need to measure it in 3 places, average it out, and then use that in your settings.
Are you using 100% infill?
Re: Prusa I3 from Maker Farm December 18, 2013 06:31AM |
Re: Prusa I3 from Maker Farm December 18, 2013 05:07PM |
Edvardas
Zenock under Printer-Firmware choose different fimware. I had to choose "5D-Absolute E"...
Re: Prusa I3 from Maker Farm December 18, 2013 05:25PM |
Re: Prusa I3 from Maker Farm December 18, 2013 06:59PM |
Edvardas
1. There is only one temperature for bed I am affraid. You can change it manually in pronterface while printing. Or type it directly into gcode after a first layer, I suppose. Have not done that myself.
2. Under Printer- hardware there is bed rougness function. I guess you should increase it so you start to print higher.
However, I start my print at paper thin gap. Gives really good adhesion.
Another thing is that kisslicer does not need to know your nozzle diameter. I found this to give impressive results as extrussion is much more precise.
Also, every guide on net tells that your line width should be equal or more than your nozzle diameter. Kisslicer does not work well with layer width set to nozzle diameter. I use 0.5mm nozzle and have set my line width to 0.55mm for both 0.2 and 0.3 layer height. This and 15mm/s perimeter speed gives impresive surface quality.
Re: Prusa I3 from Maker Farm December 18, 2013 07:25PM |
Re: Prusa I3 from Maker Farm December 18, 2013 09:19PM |
Edvardas
Uncle Bob, it is not really variable. Thing is that if there is 0.2mm gap between lines it will just lay down a chosen value (in this case 0.5mm) width in its place. Thats not perfect but I can not really trace any big negatives in that.
Re: Prusa I3 from Maker Farm December 19, 2013 12:16PM |
Edvardas
BTW, why would you want to increase temperature after first layer? Everything I have red tells to decrease it once printing is in 2nd layer.
Re: Prusa I3 from Maker Farm December 19, 2013 09:18PM |
Re: Prusa I3 from Maker Farm December 20, 2013 11:53AM |
uncle_bob
All of the default settings on the MakerFarm stuff have you printing the first layer hotter than the later layers....
