Hey Mates,
have a Prusa i2 with Wade's Extruder and Hotend v4 from reprapworld.com (0.5mm with 3mm Filament).
The printer worked fine until yesterday.
I realized that there is not enough filament comming out of the nozzle. So I started to find the error and ended up in having a jammed nozzle.
So I cleaned it (with acetone over night) and reassambled everything.
Result: Still problems!
So I tried to push some filament through the nozzle by hand and noticed that it's quite hard. Should go much easier I think?!
PEEK tube is ok, hobbed bolt is not the best but worked fine up to now.
Setting was 240°C for ABS (220-260°C) which was fine up to now.
Anybody with similar problem in his/her Reprap carrier?! Any other data needed for support?
Cheers,
Gerald
