Poor Print Quality!?!? January 09, 2014 03:36PM |
Re: Poor Print Quality!?!? January 09, 2014 04:24PM |
Re: Poor Print Quality!?!? January 09, 2014 11:22PM |
Re: Poor Print Quality!?!? January 11, 2014 01:25PM |
Re: Poor Print Quality!?!? January 11, 2014 07:31PM |
Re: Poor Print Quality!?!? January 13, 2014 12:25PM |
Re: Poor Print Quality!?!? January 13, 2014 01:43PM |
Re: Poor Print Quality!?!? January 13, 2014 07:04PM |
Re: Poor Print Quality!?!? January 13, 2014 08:03PM |
Re: Poor Print Quality!?!? January 13, 2014 08:39PM |
Re: Poor Print Quality!?!? January 14, 2014 02:17PM |
Re: Poor Print Quality!?!? January 16, 2014 12:21PM |
Re: Poor Print Quality!?!? January 16, 2014 01:52PM |
Re: Poor Print Quality!?!? January 16, 2014 01:56PM |
Re: Poor Print Quality!?!? January 17, 2014 01:01PM |
Re: Poor Print Quality!?!? January 17, 2014 01:18PM |
Re: Poor Print Quality!?!? January 17, 2014 01:31PM |
Re: Poor Print Quality!?!? January 17, 2014 05:04PM |
Re: Poor Print Quality!?!? January 17, 2014 10:27PM |
Adding a 4mm balll bearing ball that goes between the motor shaft and the threaded shaft will eliminate a lot of movement and yet still allow the flexibility needed. I have been using that method for some time and it has overcome a lot of problems. The difference with my setup is that the motors are at the bottom, so the weight of the X assembly compresses the flex coupling and the ball takes up the movement. Maybe something to think about?Quote
jcabrer
Disclaimer: This probably has nothing to do with the print problems you are showing us.
Nobody has mentioned the flex couplings. I have a Prusa Mendel with the same type of coupling. It's not a huge deal, but consider that the entire X-axis is essentially being suspended from a couple of springs. I've been putting off designing a solution for this, but now that I see it again, fresh, there is a simple printable part that will prevent the spring from stretching, but still allow flex. I'll post back when it's ready.
Re: Poor Print Quality!?!? January 18, 2014 01:43AM |
regpye
jcabrer
Re: Poor Print Quality!?!? January 20, 2014 05:19PM |
jcabrer
The root of your troubles is most likely at the hot end. What you have is a V3 Makergear or more likely a clone of that. It's not what Makergear currently recommends. Since you are printing in PLA, and using 1.75mm filament, cooling the nozzle insulator and the print is NOT optional. You will need to address this issue first, even before calibration.
Everything else will need to wait for this. No way around it, unless you want to switch to 3mm ABS and a different hot end.
Re: Poor Print Quality!?!? January 22, 2014 01:25PM |
Re: Poor Print Quality!?!? January 22, 2014 04:55PM |
Re: Poor Print Quality!?!? January 22, 2014 06:23PM |
Re: Poor Print Quality!?!? January 22, 2014 08:24PM |
