Hello,
I am building the Prusa I3 box frame. This is my first attempt to build a 3D printer.
I didn't notice in the directions that the bottom pannel has to be 3mm above the ground. That is, my bottom pannel is touching the ground.
Because of that, my Y axis brackets don't fit correctly (they will rise the whole frame in 3mm).
Would you suggest to unscrew the bottom pannel and to put it in the right position? (which I guess it wouldn't be good for the wood). Or it would be ok like it is and just amend the brackets to fit correctly (drilling them to make the hole where the threated rod goes bigger). I think that it is better the second option, but I just wonder if there is any problem having the bottom pannel touching the ground.
Thank you very much
Felipe
Edited 2 time(s). Last edit at 03/07/2014 09:34PM by felipe.
