Nearly there, but am coming a bit unstuck! April 01, 2014 05:35PM |
Re: Nearly there, but am coming a bit unstuck! April 02, 2014 04:24PM |
Re: Nearly there, but am coming a bit unstuck! April 02, 2014 04:36PM |
Re: Nearly there, but am coming a bit unstuck! April 02, 2014 07:56PM |
Re: Nearly there, but am coming a bit unstuck! April 03, 2014 02:36AM |
Re: Nearly there, but am coming a bit unstuck! April 03, 2014 03:45AM |
Re: Nearly there, but am coming a bit unstuck! April 03, 2014 06:40AM |
Re: Nearly there, but am coming a bit unstuck! April 03, 2014 06:46AM |
Re: Nearly there, but am coming a bit unstuck! April 03, 2014 08:03AM |
Re: Nearly there, but am coming a bit unstuck! April 03, 2014 01:15PM |
Re: Nearly there, but am coming a bit unstuck! April 03, 2014 02:42PM |
Re: Nearly there, but am coming a bit unstuck! April 03, 2014 04:44PM |
Re: Nearly there, but am coming a bit unstuck! April 03, 2014 04:54PM |
Re: Nearly there, but am coming a bit unstuck! April 04, 2014 04:25AM |
Re: Nearly there, but am coming a bit unstuck! April 04, 2014 05:54AM |
Re: Nearly there, but am coming a bit unstuck! April 05, 2014 11:38PM |
Mr Joshua
Well I tried the PVA juice and I don't think it really helped as I got the same fault after a while, and it broke loose. It had progressed further than previous attempts though, so perhaps I just need to experiment with the mixture.
Anyway, I tried adding on a 10mm brim, and it printed out no problem thanks to the extra grip! So I got a half decent print of a cog/gear/wheel thing at last!
Re: Nearly there, but am coming a bit unstuck! April 05, 2014 11:46PM |
Dodgey99
3DFilaprint, marked as 19-240 print temp, I print at 185 (default in Pronterface/Slic3r)
/quote]
I always print PLA at 210, never had a good print at 185.
Heated bed at 65, use Elmer's glue stick or sugar to print on.
[regpye.com.au]
"Experience is the mother of all knowledge." --Leonardo da Vinci
Re: Nearly there, but am coming a bit unstuck! April 06, 2014 05:07AM |
Re: Nearly there, but am coming a bit unstuck! April 06, 2014 07:51AM |
regpye
Dodgey99
/quote]
Strange isn't it? Clearly different PLA works at different temps (OR... our thermistors are not entirely accurate).
I'm continuing to print perfectly at 185 with PLA and no glue.
Going to try ABS next.....
Re: Nearly there, but am coming a bit unstuck! April 06, 2014 09:40AM |
Re: Nearly there, but am coming a bit unstuck! April 06, 2014 04:27PM |
Re: Nearly there, but am coming a bit unstuck! April 06, 2014 06:39PM |
Re: Nearly there, but am coming a bit unstuck! April 06, 2014 06:41PM |
Re: Nearly there, but am coming a bit unstuck! April 06, 2014 07:57PM |
Re: Nearly there, but am coming a bit unstuck! April 07, 2014 02:41AM |
Yes!Quote
Mr Joshua
Wow, I just watched the video Cliff and it sounds terrible!
Your printer looks very nice though compared to mine.
So that horrible noise etc was due to the quality of the PLA somehow?
I haven't been a member here for long but I've found it to be a very pleasant and helpful community. I think think it's because everyone is trying to learn and improve and achieve something.
I run a couple of forums and it's hard work to make sure it stays with a good atmosphere etc, but it's fulfilling too. But this forum is a pleasant place to be so far.
