Prusa i3 X Axis issue
Posted by add1ct3dd
June 17, 2014 09:12AM
Hey guys,
So on larger/more complex prints, I get a weird issue on the X axis as seen here:
Not sure what it could be linked to - possibly acceleration?
I've checked the voltage of the stepper and it's .45v and I hear no skipping at any point, and also checked the belt tension and it seems good? It's not too tight, but not too lose either.
The only thing I can think that it could be now is acceleration in Marlin - what are people's thoughts? As you can see on the left-hand shape, there is a TINY amount of slight warping, but its definitely most obvious on the right-hand piece.
Cheers,
Matt
Edited 1 time(s). Last edit at 06/17/2014 09:12AM by add1ct3dd.
Re: Prusa i3 X Axis issue
July 01, 2014 07:44AM
Looks like too much tension in x-belt, but can't be sure.
If you are using Kisslicer, you can also try lowering acceleration as much as you can (like 2mm/s or about) - helped me few times.
July 01, 2014 01:26PM
also looks too a bit of z wobble, apart the layer skips they look slanted going to the right, also check belts and also currents can cause missed steps
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
July 01, 2014 01:28PM
I ended up fixing this a while back, and has been perfect since.
I can't actually remember what the exact fix for this was, I think the screw on the motor pinion was loose, and was causing dodgy layers as you can see.
All prints well now smiling smiley.
