Hello,
I've been posting a lot here and I apologize, but I seem to be running into many end problems. I ordered a Prusa i3 from 3dPrinterCzar, and I have most everything working. All the motors turn fine, but when I try to extrude any filament, none comes out. I currently have "Greg Frost Greg's Extruder" attached, and I am attempting to print 1.5 PLA filament. The hobbed part of my hobbed bolt is lined up with my hole. When I try to manually shove it down while extruding, I still get no results. Also, I am pretty positive the temperature on the hot end is correct. I have it set for 195° C. I have tried extruding and reversing without luck. The only thing I could possibly see wrong is not having the part that bends down be tight enough but I have tried extruding while I tightly held the piece shut. Thank you for helping.
