Prusa i3 AutoBedLevelling and Servo Vibration September 05, 2014 02:00PM |
// these are the offsets to the probe relative to the extruder tip (Hotend - Probe) //X:8.00 Y:10.00 Z:39.80 #define X_PROBE_OFFSET_FROM_EXTRUDER -8 #define Y_PROBE_OFFSET_FROM_EXTRUDER -10 #define Z_PROBE_OFFSET_FROM_EXTRUDER -39.80 #define Z_RAISE_BEFORE_HOMING 4 // (in mm) Raise Z before homing (G28) for Probe Clearance. // Be sure you have this distance over your Z_MAX_POS in case #define XY_TRAVEL_SPEED 8000 // X and Y axis travel speed between probes, in mm/min #define Z_RAISE_BEFORE_PROBING 10 //How much the extruder will be raised before traveling to the first probing point. #define Z_RAISE_BETWEEN_PROBINGS 3 //How much the extruder will be raised when traveling from between next probing points //#define Z_PROBE_SLED // turn on if you have a z-probe mounted on a sled like those designed by Charles Bell #define SLED_DOCKING_OFFSET 0 // the extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like.
Re: Prusa i3 AutoBedLevelling and Servo Vibration September 05, 2014 04:00PM |
Re: Prusa i3 AutoBedLevelling and Servo Vibration October 16, 2014 05:56AM |
