prusa i3 rework extruder and jhead Mk V
November 06, 2014 08:17PM
Hi all,
I have a Prusa i3 rework extruder and I am trying to mount a jhead from SainSmart to it. Has anyone done this? Is there an adapter? Do I have to remove the brass fitting?
Any help would be great.
Re: prusa i3 rework extruder and jhead Mk V
November 06, 2014 08:36PM
That's not a JHead MK V. This link is to a real JHead MK V [www.hotends.com]
There is a brass fitting on the end of the Sainsmart that will be problematic with a Rework extruder. It looks like that's the guide fitting for a Bowden extruder and the stock Rework uses a modified geared Wade's extruder. If you can remove the brass fitting you might be able to get it to mount in the Rework extruder depending the size of the PEEK. If you can remove the brass fitting you might be able to fashion a mount plate if the grooves aren't the right size.
November 07, 2014 01:16AM
Ok, thanks for the reply vegasloki. I can get the brass fitting off.so I will try that.
November 07, 2014 09:47AM
What are the best hotends for the rework extruder?
November 07, 2014 12:28PM
erocfx
I am using a jhead from MakerFarm on my recent rework build.
Used the same jhead on my first i3 build as well.
[www.makerfarm.com]
I mainly print with PLA but it works well with PETG and ABS
Steve
My updated Instructable on our Prusa i3 Build
[www.instructables.com]
November 08, 2014 04:23PM
Ok, I took off the brass fitting and it mounted fine. seems to be working great. Thanks for the help.
November 08, 2014 05:41PM
If that picture is your hot end.
Whatever you do get rid of all that tape around the body of the head.
The kapton tape should just be round the heater block.
You need airflow to keep the body cool and the j-heads also benefit from a fan aimed at the black body.
Gordon
November 08, 2014 06:00PM
Hey Gordon,
that is just the picture from the website. But the one they shipped is blocking some airflow, so thanks for the tip!!
