Replikeo Prusa i3
December 09, 2014 12:30PM
Hi Guys,
I've just assembled my replikeo, but i've some problems, I'm using pronterface, to check everything. for now only X axis works without any problem.
The Z and Y Axis makes a lot of noise when I click the home button. With small steps, it works ok.
I've already check the endstops with a multimeter, It seems OK.
configuration.h attached and also the video below:
video: (removed, solution below)
[www.youtube.com]
any suggestions?
Thanks in advance.
Edited 1 time(s). Last edit at 12/09/2014 03:49PM by gordonpt.
open | download - configuration.h (34.6 KB)
Re: Replikeo Prusa i3
December 09, 2014 12:58PM
I had same problem with X and Y, just change your configuration, try to invert the motor rotation...
#define INVERT_Y_DIR false   // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR false   // for Mendel set to false, for Orca set to true
The mine is so, and that's ok:
#define INVERT_X_DIR true    // for Mendel set to false, for Orca set to true
#define INVERT_Z_DIR true     // for Mendel set to false, for Orca set to true
Edited 1 time(s). Last edit at 12/09/2014 01:00PM by raphaelbruno3d.
December 09, 2014 12:59PM
Edited 2 time(s). Last edit at 12/09/2014 01:01PM by raphaelbruno3d.
December 09, 2014 01:26PM
No.
I've already changed it and it does the same, but on the opposite side. :\
December 09, 2014 02:07PM
Ok the Y axis endstoper its Ok
Bad wiring, I need to connect it correctly, like in this link: [forums.reprap.org]
because it is a Y-max position.
But the z axis still make a lot of noise when I press "home", and it only stops if I press manually the end stopper, and it adjusts it self, like 1cm down (like if it really touch on the sensor)
my power supply is an S-400-12, and its giving me 12.2v I've tried to adjust it to 12.4v, but nothing have changed...
December 09, 2014 02:16PM
Ok .. my bad, sorry for didn't search it before.
It's a acceleration/jerk problems..
I've changed this values based in this post: [forums.reprap.org]
#define HOMING_FEEDRATE {3000, 3000, 100, 0}
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4100,650}
#define DEFAULT_MAX_FEEDRATE {120, 120, 2.5, 50}
#define DEFAULT_MAX_ACCELERATION {120,120,5,800}
#define DEFAULT_ACCELERATION 50
#define DEFAULT_RETRACT_ACCELERATION 50
#define DEFAULT_XYJERK 20 // (mm/sec)
#define DEFAULT_ZJERK 1 // (mm/sec)
#define DEFAULT_EJERK 20 // (mm/sec)
I'll make some tests, and then post it where.
thank you
December 09, 2014 03:32PM
This is my first print.
It broke when I tried to remove from the glass.
I definitely need to calibrate it, any suggestions for where start?
Thank you
open | download - 20mm-box.stl (3 KB)
open | download - 2014-12-09 20.14.04.jpg (123.3 KB)
December 11, 2014 12:50PM
Is it normal if the extruder moves? I can easy move it with hand..
sometimes the extruder moves it self.. just printing a simples cube (image attached above)
thanks
December 11, 2014 01:04PM
It actually balance!
see the pictures attached, and compare.
I also will change the bed, because is one (fiber) isn't 100% flat, I'll use glass instead. (the z axis end stoper is Ok in all corners, but in the middle it touch)
temperatures:
bed: 102c
extruder: 230c
thankyou
open | download - balance1.jpg (122.2 KB)
open | download - balance2.jpg (122.6 KB)
open | download - object.jpg (150.1 KB)
December 11, 2014 05:28PM
I put the 2 screws, but isn't enough, it balance alone when is printing.
Does anyone had this problem?
Thanks for helping
